查看: 6444|回复: 15
[资料] TLF (Timing library format)
发表于 2010-7-7 09:52:25 | 显示全部楼层 |阅读模式
TLL :  This manual contains reference information about the timing library format(TLF). This manual is intended for timing and power library develpers. To use TKL you should be familiar with the concepts of cell modeling for both timing and power,circuit delays, and timing checks. You should also know how circuit delays and timing checks, and power dissipation are affected by circuit parameters.
说明: 如果你有装 SOC ,会在  $install/doc/ct_tlfref/ 下发现此文件,如果没有安装可以下载看看.
      Timing Library Format Reference
       PDF 文件,共478页
        Product Version 4.5
        October 2000
ct_tlfref.pdf
2.69 MB, 下载次数: 255 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-8-4 09:02:51 | 显示全部楼层
谢谢。。。
发表于 2010-8-16 10:15:57 | 显示全部楼层
Hi
Thanks for the materials dude
发表于 2010-8-24 14:08:17 | 显示全部楼层
good, thanks.
发表于 2010-8-24 14:09:44 | 显示全部楼层
good, thanks.
发表于 2010-11-13 18:38:25 | 显示全部楼层
3qqqqqqqqqqqqqqqqqqqq
发表于 2010-12-24 10:17:06 | 显示全部楼层
回复 1# jiangbowen
    谢谢分享,一直想找这种资料看看
发表于 2011-2-9 15:57:46 | 显示全部楼层
学习学习
发表于 2011-11-7 14:59:47 | 显示全部楼层
收了,多谢
发表于 2011-11-29 22:55:19 | 显示全部楼层
多谢分享
GMT+8, 2025-12-25 12:14 , Processed in 0.153230 second(s), 7 queries , Gzip On, Redis On.
