查看: 9726|回复: 8
求助关于Sentaurus 安装问题
发表于 2010-7-3 10:29:26 | 显示全部楼层 |阅读模式
我 装好了Sentaurus 2008.09 ,但是运行Lmgrd 时候
22:28:32 (snpslmd) Checking the integrity of the license file....
22:28:32 (snpslmd) Valid SSS feature found.
22:28:32 (snpslmd) The feature is needed to enable the other keys in your license file.
22:28:32 (snpslmd) ------------------------------------------------------------------
22:28:51 (snpslmd) TCP_NODELAY NOT enabled
22:28:52 (snpslmd) OUT: "swb_all" root@localhost.localdomain
22:28:52 (snpslmd) UNSUPPORTED: "SK_swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))22:28:52 (snpslmd) IN: "swb_all" root@localhost.localdomain
运行GENESISe
[root@localhost ~]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version A-2008.09                           ***
***                        (1.4, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2009                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
License checkout failed: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       swb_all
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-8,544
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2008.09"
        * server name is "localhost.localdomain"
        * daemon is "snpslmd"
        * code is "CD0C4C73CCD442483810"
        * expiry date is "31-dec-2019"
        * STROOT is "/usr/synopsys/A_2008.09-SP1/bin/.."
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/2"
        * user is "root"
请问大家有没有解?
 楼主| 发表于 2010-7-3 10:52:08 | 显示全部楼层
ding   shang
 楼主| 发表于 2010-7-3 12:21:59 | 显示全部楼层
终于搞定了,和 Synopsys SSS Feature Keygen  EFA LicGen 0.4b 版本有问题
发表于 2010-9-4 18:32:43 | 显示全部楼层
那具体是怎么解决的啊~?
发表于 2010-9-6 15:33:13 | 显示全部楼层
Thanks
发表于 2010-11-16 15:41:13 | 显示全部楼层
看一下到底咋样
发表于 2010-11-17 15:03:02 | 显示全部楼层
关注中,我也想安装
发表于 2011-1-4 09:53:46 | 显示全部楼层
发表于 2016-9-18 14:53:39 | 显示全部楼层
是换了这两个的版本,用最新的就能解决么,亲
GMT+8, 2025-12-22 02:51 , Processed in 0.026244 second(s), 5 queries , Gzip On, Redis On.
