发表于 2010-6-29 08:50:32
显示全部楼层
content
SPECIAL ISSUE ON THE 35TH EUROPEAN SOLID-STATE CIRCUITS CONFERENCE (ESSCIRC 2009)
Introduction to the Special Issue on the 35th European Solid-State Circuits Conference (ESSCIRC 2009) ................
....................................................................................... Y.Deval, K. A. A. Makinwa, and S. Rusu 1270
Energy Supply and ULP Detection Circuits for an RFID Localization System in 130 nm CMOS ..........................
............................................................................................. C.DeRoover andM. S. J. Steyaert 1273
A 60 GHz Power Amplifier With 14.5 dBm Saturation Power and 25% Peak PAE in CMOS 65 nm SOI ..................
. . A. Siligaris, Y. Hamada, C. Mounet, C. Raynaud, B. Martineau, N. Deparis, N. Rolland, M. Fukaishi, and P. Vincent 1286
A 0.06 mm 11 mW Local Oscillator for the GSM Standard in 65 nm CMOS . . ..............................................
............................................. S.D. Toso, A. Bevilacqua, M. Tiebout, N. Da Dalt, A. Gerosa, and A. Neviani 1295
A 200 μA Duty-Cycled PLL for Wireless Sensor Nodes in 65 nm CMOS ....................................................
............................. S.Drago,D.M.W. Leenaerts, B. Nauta, F. Sebastiano, K. A. A. Makinwa, and L. J. Breems 1305
A Single-Chip CMOS UHF RFID Reader Transceiver for Chinese Mobile Applications ....................................
................. L. Ye,H. Liao, F. Song, J. Chen, C. Li, J. Zhao, R. Liu, C. Wang, C. Shi, J. Liu, R. Huang, and Y. Wang 1316
An 11.1 Gbps Analog PRML Receiver for Electronic Dispersion Compensation of Fiber Optic Communications ........
....................................................................................................................... S. Elahmadi,
M. Bussmann, D. Baranauskas, D. Zelenin, J. Edwards, K. Tran, L. F. Linder, C. Gill, H. Tan, D. Ng, and S. El-Ahmadi 1330
A16 16 Pixel Distance Sensor With In-Pixel Circuitry That Tolerates 150 klx of Ambient Light .........................
.................................................................................. G. Zach,M. Davidovic, and H. Zimmermann 1345
A 134-Pixel CMOS Sensor for Combined Time-of-Flight and Optical Triangulation 3-D Imaging .........................
................................................ O. Sgrott, D. Mosconi, M. Perenzoni, G. Pedretti, L. Gonzo, and D. Stoppa 1354
Power Reduction in Continuous-Time Delta-Sigma Modulators Using the Assisted Opamp Technique ....................
........................................................................................................... S.Pavan and P. Sankar 1365
A 3-V, 6-Bit C-2C Digital-to-Analog Converter Using Complementary Organic Thin-Film Transistors on Glass .........
............................................................. W. Xiong, Y. Guo, U. Zschieschang, H. Klauk, and B. Murmann 1380
Closed-Loop Class-D Amplifier With Nonlinear Loop Integrators ........... ........... B.Krabbenborg and M. Berkhout 1389
A 118.4 GB/s Multi-Casting Network-on-Chip With Hierarchical Star-Ring Combined Topology for Real-Time Object
Recognition ............................ ............................ J.-Y. Kim, J. Park, S. Lee, M. Kim, J. Oh, and H.-J. Yoo 1399
A 2.5-GHz, 6.9-mW, 45-nm-LP CMOS, Modulator Based on Standard Cell Design With Time-Interleaving ........
................................. P. Madoglio, A. Ravi, L. Cuellar, S. Pellerano, P. Seddighrad, I. Lomeli, and Y. Palaskas 1410 |
content.PDF
42.32 KB, 下载次数: 12
, 下载积分:
资产 -2 信元, 下载支出 2 信元
