查看: 15602|回复: 37
Conformal LEC
发表于 2010-6-25 12:57:56 | 显示全部楼层 |阅读模式
Cadence Encounter Conformal Support:
1. Introduction
    1.1 Formal verification versus simulation
    1.2 Formal verification: what you need know
2. Formal Verification Design Flow
    2.1 Quartus II integrated synthesis
    2.2 EDA tool support for quartus II integrated synthesis
    2.3 Synplify Pro
    2.4 EDA tool supoort for synplify pro
3. RTL coding guidelines for quartus II integrated synthesis
    3.1 synthesis directives and attributes
    3.2 stuck-at registers
    3.3 ROM, LPM_DIVIDE, and shift register inference
    3.4 RAM interface
    3.5 Latch interface
    3.6 Combiantional loops
    3.7 Finite state machine coding styles
4. Black boxes in the encounter conformal flow
    4.1 TCL command
    4.2 GUI
5. Generating the post-fit netlist output and the encounter conformal setup files
    5.1 the quartus II software generated files, formal verification scripts and directories
6. Understanding the formal verification scripts for encounter conformal
    6.1 the encounter conformal commands within the quartus II software-generated scripts
7. Comparing design using encounter conformal
    7.1 running the encounter conformal software from the gui
    7.2 runnign the encounter conformal software from a system command prompt
Alter_conformal_support.pdf
462.79 KB, 下载次数: 252 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-6-25 13:10:33 | 显示全部楼层
thanks
发表于 2010-7-2 21:10:07 | 显示全部楼层
good, thanks.
发表于 2010-7-4 20:25:00 | 显示全部楼层
good, thanks.
发表于 2010-7-11 14:31:02 | 显示全部楼层
sanks
发表于 2010-7-26 17:09:42 | 显示全部楼层
ALTERA的,谢谢~~
发表于 2010-8-10 00:05:20 | 显示全部楼层
谢谢楼主。。。。
发表于 2010-8-17 16:22:30 | 显示全部楼层
不错不错
发表于 2010-8-17 22:26:50 | 显示全部楼层
我还以为是tool呢,原来是doc
发表于 2010-9-4 13:36:18 | 显示全部楼层
谢谢楼主!!!!
GMT+8, 2025-12-26 21:32 , Processed in 0.061139 second(s), 6 queries , Gzip On, Redis On.
