楼主: chaogao
[资料] Fundamentals of Power Semiconductor Devices(PDF,非扫描)
发表于 2010-7-8 14:22:50 | 显示全部楼层
thanks               guys
发表于 2010-7-9 11:34:52 | 显示全部楼层
谢谢共享,顶一个.
发表于 2010-7-29 17:47:47 | 显示全部楼层
感谢分享,谢谢!!!!!!
发表于 2010-7-29 17:51:28 | 显示全部楼层
感谢分享,谢谢!!!!!!
发表于 2010-7-29 18:34:37 | 显示全部楼层
Pass,  Rnorm=4.747E+07   Ratio=1.902E-01   Tdamp=6.667E-01
  XR      2    4.3248E-02  3.5672E+01  1.3284E+00     0
Pass,  Rnorm=1.217E+06   Ratio=2.564E-02   Tdamp=9.546E-01
  XR      3    3.1600E-02  3.5518E+01  9.2915E-01     0
Pass,  Rnorm=1.581E+03   Ratio=1.299E-03   Tdamp=9.950E-01
  XR      4    5.6876E-03  3.7781E+02  3.5204E-01     0
Pass,  Rnorm=1.086E+02   Ratio=6.871E-02   Tdamp=1.000E+00
  XR      5    4.9769E-09  4.1858E+01  3.7620E-02     0
Pass,  Rnorm=3.969E-05   Ratio=3.654E-07   Tdamp=1.000E+00
  XR      6    2.8576E-10  6.2589E-01  5.4298E-04     0
Pass,  Rnorm=5.262E-07   Ratio=1.326E-02   Tdamp=1.000E+00
  XR      7    1.7732E-11  2.3728E-04  1.5185E-05     0
Pass,  Rnorm=1.554E-10   Ratio=2.953E-04   Tdamp=1.000E+00
  XR      8    3.2162E-17  0.0000E+00  0.0000E+00     0
... Calculating device resistance for continuation.
Bi-CGSTAB Failed to converge to tolerances, iiter= 2
Using solution any way.  5.67162329E-24
   Electrode       Voltage       Flux      I(Electron)    I(Hole)     I(Total)
      Name         (Volts)    (Coul/mic.)   (A/micron)   (A/micron)   (A/micron)
gate             0.0000E+00  -4.2675E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9736E-18  -1.1705E-12  -1.1705E-12
drain            3.9101E+01   1.0862E-16   1.1715E-12  -1.0175E-15   1.1705E-12
Absolute convergence criterion met for Poisson
Absolute convergence criterion met for continuity
Total cpu time for bias point =    0.61 minutes
Total cpu time =   14.74 minutes
  Continuation method:
Slope: 1.431E+00      Device Resistance: 2.288E+13
   V:   40.6433     I: 1.238E-12
   R: 1.000E+07    Va: 4.064E+01
Lte: 4.774E-02    dV: 1.543E+00    dI: 6.742E-14
  Projection  used to find initial guess.
Solution for Bias:
   V(gate)            =  0.0000000E+00     V(source)          =  0.0000000E+00
   V(drain)           =  4.0643322E+01
norm   iter    v-error     n-error     p-error     iiter
  XR      1    4.5223E-02  8.7856E+00  2.4844E+00     0
Pass,  Rnorm=1.454E+08   Ratio=2.304E-01   Tdamp=6.667E-01
  XR      2    2.9514E-02  7.5131E+01  9.6893E-01     0
Pass,  Rnorm=5.042E+06   Ratio=3.467E-02   Tdamp=9.455E-01
  XR      3    2.1313E-02  8.0888E+00  9.3215E-01     0
Pass,  Rnorm=5.591E+02   Ratio=1.109E-04   Tdamp=1.000E+00
  XR      4    3.3507E-04  1.5639E+01  3.9859E-01     0
Pass,  Rnorm=3.700E+00   Ratio=6.618E-03   Tdamp=1.000E+00
  XR      5    2.1361E-09  9.6561E+00  1.2172E-02     0
Pass,  Rnorm=3.312E-06   Ratio=8.952E-07   Tdamp=1.000E+00
  XR      6    1.4738E-10  1.8152E-01  4.0619E-04     0
Pass,  Rnorm=4.935E-08   Ratio=1.490E-02   Tdamp=1.000E+00
  XR      7*   4.5951E-13  5.2684E-06  2.8978E-07     0
Pass,  Rnorm=7.549E-11   Ratio=1.530E-03   Tdamp=1.000E+00
  XR      8    1.2886E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  7.88104045E-29
gate             0.0000E+00  -4.3679E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9840E-18  -1.2182E-12  -1.2182E-12
drain            4.0643E+01   1.0862E-16   1.2192E-12  -1.0592E-15   1.2182E-12
Total cpu time for bias point =    0.59 minutes
Total cpu time =   15.33 minutes
Slope: 1.278E+00      Device Resistance: 2.560E+13
   V:   42.3690     I: 1.286E-12
   R: 1.000E+07    Va: 4.237E+01
Lte: 4.501E-02    dV: 1.726E+00    dI: 6.741E-14
Solution for Bias:
   V(drain)           =  4.2368985E+01
  XR      1    3.3094E-02  8.8143E+00  4.0863E+00     0
Pass,  Rnorm=1.786E+08   Ratio=2.740E-01   Tdamp=6.667E-01
  XR      2    2.6673E-02  3.1828E+02  2.8005E+00     0
Pass,  Rnorm=7.159E+06   Ratio=4.008E-02   Tdamp=9.359E-01
  XR      3    2.1722E-02  1.8287E+01  9.3615E-01     0
Pass,  Rnorm=5.378E+03   Ratio=7.512E-04   Tdamp=9.950E-01
  XR      4    2.6586E-03  2.9858E+01  7.2518E-01     0
Pass,  Rnorm=4.076E+00   Ratio=7.579E-04   Tdamp=1.000E+00
  XR      5    6.3781E-06  1.1055E+01  6.4010E-02     0
Pass,  Rnorm=1.697E-03   Ratio=4.163E-04   Tdamp=1.000E+00
  XR      6    4.2810E-10  2.8208E-01  1.9430E-02     0
Pass,  Rnorm=9.883E-11   Ratio=5.824E-08   Tdamp=1.000E+00
  XR      7    5.3040E-13  0.0000E+00  0.0000E+00     0
Using solution any way.  1.97379932E-22
gate             0.0000E+00  -4.4746E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9860E-18  -1.2637E-12  -1.2637E-12
drain            4.2369E+01   1.0862E-16   1.2648E-12  -1.0991E-15   1.2637E-12
Total cpu time for bias point =    0.57 minutes
Total cpu time =   15.91 minutes
Slope: 8.779E-01      Device Resistance: 3.740E+13
   V:   44.5597     I: 1.322E-12
   R: 1.000E+07    Va: 4.456E+01
Lte: 5.444E-02    dV: 2.191E+00    dI: 5.858E-14
Solution for Bias:
   V(drain)           =  4.4559750E+01
  XR      1    2.5007E-02  1.0593E+01  3.3002E+01     0
Pass,  Rnorm=4.620E+06   Ratio=1.451E-01   Tdamp=6.667E-01
  XR      2    2.4055E-02  8.4809E+01  3.1887E+01     0
Pass,  Rnorm=5.656E+04   Ratio=1.224E-02   Tdamp=9.650E-01
  XR      3    8.6793E-03  9.2599E+00  2.4057E+00     0
Pass,  Rnorm=1.885E+01   Ratio=3.333E-04   Tdamp=9.950E-01
  XR      4    6.1445E-04  3.0382E+01  1.0326E+00     0
Pass,  Rnorm=1.258E+00   Ratio=6.672E-02   Tdamp=1.000E+00
  XR      5    2.1036E-09  8.2465E+00  9.9394E-01     0
Pass,  Rnorm=5.170E-03   Ratio=4.111E-03   Tdamp=1.000E+00
  XR      6    6.6340E-10  5.7221E-03  7.3554E-01     0
Pass,  Rnorm=6.342E-08   Ratio=1.227E-05   Tdamp=1.000E+00
  XR      7    1.2846E-11  7.8424E-05  5.9509E-04     0
Pass,  Rnorm=3.122E-10   Ratio=4.923E-03   Tdamp=1.000E+00
  XR      8*   9.3649E-17  0.0000E+00  0.0000E+00     0
Using solution any way.  9.06473067E-12
gate             0.0000E+00  -4.6051E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9925E-18  -1.3066E-12  -1.3066E-12
drain            4.4560E+01   1.0863E-16   1.3078E-12  -1.1367E-15   1.3066E-12
Total cpu time for bias point =    0.56 minutes
Total cpu time =   16.47 minutes
Slope: 5.939E-01      Device Resistance: 5.599E+13
   V:   47.1845     I: 1.354E-12
   R: 1.000E+07    Va: 4.718E+01
Lte: 6.991E-02    dV: 2.625E+00    dI: 4.688E-14
Solution for Bias:
   V(drain)           =  4.7184527E+01
  XR      1    2.6243E-02  4.3459E+01  1.2655E+01     0
Pass,  Rnorm=1.054E+08   Ratio=1.637E-01   Tdamp=6.667E-01
  XR      2    9.2407E-03  2.0563E+02  1.2089E+01     0
Pass,  Rnorm=1.349E+06   Ratio=1.280E-02   Tdamp=9.607E-01
  XR      3    4.6176E-03  1.0650E+02  1.7364E+00     0
Pass,  Rnorm=5.402E+01   Ratio=4.005E-05   Tdamp=1.000E+00
  XR      4    3.8042E-04  1.7422E+02  1.0039E+00     0
Pass,  Rnorm=1.894E-01   Ratio=3.507E-03   Tdamp=1.000E+00
  XR      5    8.2497E-07  1.0235E+03  1.6428E+00     0
Pass,  Rnorm=5.465E-03   Ratio=2.885E-02   Tdamp=1.000E+00
  XR      6    7.5149E-10  4.3173E-03  6.7826E-02     0
Pass,  Rnorm=3.210E-09   Ratio=5.875E-07   Tdamp=1.000E+00
  XR      7    1.0128E-14  0.0000E+00  0.0000E+00     0
Using solution any way.  2.26138592E-18
gate             0.0000E+00  -4.7572E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9866E-18  -1.3461E-12  -1.3461E-12
drain            4.7185E+01   1.0863E-16   1.3473E-12  -1.1712E-15   1.3461E-12
Total cpu time for bias point =    0.54 minutes
Total cpu time =   17.01 minutes
Slope: 5.005E-01      Device Resistance: 6.807E+13
   V:   50.0657     I: 1.388E-12
   R: 1.000E+07    Va: 5.007E+01
Lte: 5.991E-02    dV: 2.881E+00    dI: 4.233E-14
Solution for Bias:
   V(drain)           =  5.0065666E+01
  XR      1    3.2626E-02  1.3172E+01  2.4990E+02     0
Pass,  Rnorm=7.012E+07   Ratio=1.188E-01   Tdamp=6.667E-01
  XR      2    5.6741E-03  5.9703E+01  7.4088E+00     0
Pass,  Rnorm=2.685E+05   Ratio=3.829E-03   Tdamp=9.712E-01
  XR      3    5.2636E-03  2.0754E+01  1.4740E+00     0
Pass,  Rnorm=2.475E+01   Ratio=9.220E-05   Tdamp=1.000E+00
  XR      4    1.6760E-04  3.5579E+01  9.9034E-01     0
Pass,  Rnorm=5.919E-02   Ratio=2.391E-03   Tdamp=1.000E+00
  XR      5    1.3295E-09  5.4271E+01  8.1724E-01     0
Pass,  Rnorm=9.093E-06   Ratio=1.536E-04   Tdamp=1.000E+00
  XR      6    1.7326E-10  7.1930E-04  3.5860E-03     0
Pass,  Rnorm=3.054E-11   Ratio=3.358E-06   Tdamp=1.000E+00
  XR      7    1.7463E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  7.91040699E-22
gate             0.0000E+00  -4.9199E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9827E-18  -1.3839E-12  -1.3840E-12
drain            5.0066E+01   1.0863E-16   1.3852E-12  -1.2041E-15   1.3840E-12
Total cpu time =   17.59 minutes
Slope: 4.516E-01      Device Resistance: 7.777E+13
   V:   53.1781     I: 1.424E-12
   R: 1.000E+07    Va: 5.318E+01
Lte: 6.861E-02    dV: 3.112E+00    dI: 4.002E-14
Solution for Bias:
   V(drain)           =  5.3178163E+01
  XR      1    3.6592E-02  3.4135E+01  1.3267E+02     0
Pass,  Rnorm=2.253E+07   Ratio=1.229E-01   Tdamp=6.667E-01
  XR      2    3.8765E-03  2.2802E+02  3.3612E+00     0
Pass,  Rnorm=7.596E+04   Ratio=3.372E-03   Tdamp=9.702E-01
  XR      3    4.8117E-03  1.2435E+01  1.2706E+00     0
Pass,  Rnorm=1.088E+00   Ratio=1.433E-05   Tdamp=1.000E+00
  XR      4    1.3434E-04  4.7075E+01  1.7628E+00     0
Pass,  Rnorm=6.403E-02   Ratio=5.883E-02   Tdamp=1.000E+00
  XR      5    1.2501E-09  1.0654E+02  4.9534E-01     0
Pass,  Rnorm=7.590E-06   Ratio=1.185E-04   Tdamp=1.000E+00
  XR      6    1.1779E-10  2.4195E-04  2.9229E-03     0
Pass,  Rnorm=1.500E-09   Ratio=1.976E-04   Tdamp=1.000E+00
  XR      7*   2.0199E-16  0.0000E+00  1.0220E-07     0
Using solution any way.  1.10171783E-09
gate             0.0000E+00  -5.0916E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9955E-18  -1.4199E-12  -1.4199E-12
drain            5.3178E+01   1.0863E-16   1.4212E-12  -1.2352E-15   1.4199E-12
Total cpu time =   18.15 minutes
Slope: 4.396E-01      Device Resistance: 8.268E+13
   V:   56.4973     I: 1.460E-12
   R: 1.000E+07    Va: 5.650E+01
Lte: 6.117E-02    dV: 3.319E+00    dI: 4.015E-14
Solution for Bias:
   V(drain)           =  5.6497284E+01
  XR      1    4.0213E-02  1.2566E+01  5.4994E+01     0
Pass,  Rnorm=3.859E+06   Ratio=2.529E-01   Tdamp=6.667E-01
  XR      2    4.1392E-03  3.0631E+02  4.0696E+00     0
Pass,  Rnorm=3.103E+04   Ratio=8.042E-03   Tdamp=9.405E-01
  XR      3    4.6323E-03  1.7822E+02  1.2093E+00     0
Pass,  Rnorm=1.089E+03   Ratio=3.508E-02   Tdamp=1.000E+00
  XR      4    1.6586E-04  4.7016E+02  9.7473E-01     0
Pass,  Rnorm=2.242E+01   Ratio=2.060E-02   Tdamp=1.000E+00
  XR      5    4.5090E-09  2.4895E+01  6.6734E-01     0
Pass,  Rnorm=1.356E-04   Ratio=6.050E-06   Tdamp=1.000E+00
  XR      6    2.7109E-10  1.2694E-03  1.2304E-02     0
Pass,  Rnorm=1.167E-08   Ratio=8.604E-05   Tdamp=1.000E+00
  XR      7*   1.1478E-15  3.4677E-08  4.8973E-07     0
Pass,  Rnorm=2.461E-11   Ratio=2.109E-03   Tdamp=1.000E+00
  XR      8    9.9700E-17  0.0000E+00  0.0000E+00     0
gate             0.0000E+00  -5.2703E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9906E-18  -1.4541E-12  -1.4541E-12
drain            5.6497E+01   1.0863E-16   1.4554E-12  -1.2645E-15   1.4541E-12
Total cpu time for bias point =    0.72 minutes
Total cpu time =   18.87 minutes
Slope: 3.695E-01      Device Resistance: 1.020E+14
   V:   60.1101     I: 1.490E-12
   R: 1.000E+07    Va: 6.011E+01
Lte: 6.225E-02    dV: 3.613E+00    dI: 3.541E-14
Solution for Bias:
   V(drain)           =  6.0110071E+01
  XR      1    4.3921E-02  1.1133E+01  2.3375E+02     0
Pass,  Rnorm=5.534E+06   Ratio=1.236E-01   Tdamp=6.667E-01
  XR      2    3.1130E-03  5.3436E+01  3.5859E+00     0
Pass,  Rnorm=1.940E+04   Ratio=3.506E-03   Tdamp=9.700E-01
  XR      3    4.0575E-03  2.3935E+01  1.1265E+00     0
Pass,  Rnorm=1.105E+00   Ratio=5.698E-05   Tdamp=1.000E+00
  XR      4    1.0665E-04  2.5661E+01  9.2811E-01     0
Pass,  Rnorm=1.428E-01   Ratio=1.292E-01   Tdamp=1.000E+00
  XR      5    1.3371E-09  1.0286E+02  4.8978E-02     0
Pass,  Rnorm=1.171E-05   Ratio=8.198E-05   Tdamp=1.000E+00
  XR      6    8.1447E-11  8.7233E-05  2.2882E-03     0
Pass,  Rnorm=3.299E-09   Ratio=2.818E-04   Tdamp=1.000E+00
  XR      7*   1.2597E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  2.88581894E-06
gate             0.0000E+00  -5.4604E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9929E-18  -1.4876E-12  -1.4876E-12
drain            6.0110E+01   1.0863E-16   1.4889E-12  -1.2929E-15   1.4876E-12
Total cpu time for bias point =    0.49 minutes
Total cpu time =   19.36 minutes
Slope: 3.717E-01      Device Resistance: 1.054E+14
   V:   63.9484     I: 1.524E-12
   R: 1.000E+07    Va: 6.395E+01
Lte: 6.540E-02    dV: 3.838E+00    dI: 3.641E-14
Solution for Bias:
   V(drain)           =  6.3948422E+01
  XR      1    4.9323E-02  5.3436E+01  1.5264E+02     0
Pass,  Rnorm=2.730E+06   Ratio=1.277E-01   Tdamp=6.667E-01
  XR      2    2.8400E-03  3.5089E+02  6.7369E+00     0
Pass,  Rnorm=1.096E+04   Ratio=4.015E-03   Tdamp=9.691E-01
  XR      3    3.6060E-03  4.0580E+02  1.0800E+00     0
Pass,  Rnorm=2.005E+00   Ratio=1.830E-04   Tdamp=1.000E+00
  XR      4    1.0203E-04  9.5891E+01  8.5552E-01     0
Pass,  Rnorm=1.998E-01   Ratio=9.961E-02   Tdamp=1.000E+00
  XR      5    1.3457E-09  2.0093E+02  3.8573E-02     0
Pass,  Rnorm=8.066E-06   Ratio=4.038E-05   Tdamp=1.000E+00
  XR      6    8.6839E-11  8.4235E-05  2.5220E-03     0
Pass,  Rnorm=8.008E-10   Ratio=9.929E-05   Tdamp=1.000E+00
  XR      7*   1.8224E-16  0.0000E+00  6.7633E-08     0
Using solution any way.  8.43888864E-14
gate             0.0000E+00  -5.6589E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9871E-18  -1.5194E-12  -1.5194E-12
drain            6.3948E+01   1.0863E-16   1.5207E-12  -1.3193E-15   1.5194E-12
Total cpu time =   19.85 minutes
Slope: 3.329E-01      Device Resistance: 1.226E+14
   V:   68.0820     I: 1.553E-12
   R: 1.000E+07    Va: 6.808E+01
Lte: 6.730E-02    dV: 4.134E+00    dI: 3.372E-14
Solution for Bias:
   V(drain)           =  6.8081973E+01
  XR      1    5.5986E-02  1.9926E+01  5.8142E+01     0
Pass,  Rnorm=2.748E+08   Ratio=1.282E-01   Tdamp=6.667E-01
  XR      2    9.5459E-03  2.9427E+01  4.4054E+00     0
Pass,  Rnorm=8.428E+05   Ratio=3.067E-03   Tdamp=9.689E-01
  XR      3    3.1913E-03  4.9937E+01  2.7088E+00     0
Pass,  Rnorm=6.962E+01   Ratio=8.260E-05   Tdamp=1.000E+00
  XR      4    9.9192E-05  3.6192E+02  8.9765E-01     0
Pass,  Rnorm=5.330E-01   Ratio=7.655E-03   Tdamp=1.000E+00
  XR      5    2.0949E-09  6.1649E+01  7.2352E-02     0
Pass,  Rnorm=4.585E-05   Ratio=8.603E-05   Tdamp=1.000E+00
  XR      6    1.1749E-10  1.0489E-04  3.4083E-03     0
Pass,  Rnorm=2.134E-08   Ratio=4.654E-04   Tdamp=1.000E+00
  XR      7*   3.0928E-15  0.0000E+00  2.6176E-07     0
Pass,  Rnorm=1.354E-10   Ratio=6.344E-03   Tdamp=1.000E+00
  XR      8    3.4406E-16  0.0000E+00  0.0000E+00     0
gate             0.0000E+00  -5.8692E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0017E-18  -1.5500E-12  -1.5500E-12
drain            6.8082E+01   1.0863E-16   1.5513E-12  -1.3439E-15   1.5500E-12
Total cpu time =   20.41 minutes
Slope: 3.125E-01      Device Resistance: 1.362E+14
   V:   72.5074     I: 1.582E-12
   R: 1.000E+07    Va: 7.251E+01
Lte: 7.294E-02    dV: 4.425E+00    dI: 3.248E-14
Solution for Bias:
   V(drain)           =  7.2507385E+01
  XR      1    5.5456E-02  1.3949E+01  8.0777E+01     0
Pass,  Rnorm=2.514E+07   Ratio=6.114E-01   Tdamp=6.667E-01
  XR      2    4.9230E-03  1.4907E+02  3.2442E+02     0
Pass,  Rnorm=8.160E+06   Ratio=3.247E-01   Tdamp=8.674E-01
  XR      3    7.8247E-03  1.7499E+01  9.9544E-01     0
Pass,  Rnorm=2.548E+04   Ratio=3.122E-03   Tdamp=9.758E-01
  XR      4    3.3827E-03  3.6013E+02  9.6251E-01     0
Pass,  Rnorm=2.804E+00   Ratio=1.101E-04   Tdamp=1.000E+00
  XR      5    2.2268E-09  1.5578E+02  4.3246E-02     0
Pass,  Rnorm=6.175E-04   Ratio=2.202E-04   Tdamp=1.000E+00
  XR      6    3.5255E-10  1.3003E-01  5.8506E-03     0
Pass,  Rnorm=2.478E-10   Ratio=4.014E-07   Tdamp=1.000E+00
  XR      7    7.2450E-14  0.0000E+00  0.0000E+00     0
Using solution any way.  2.68390675E-17
gate             0.0000E+00  -6.0874E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -6.9996E-18  -1.5800E-12  -1.5800E-12
drain            7.2507E+01   1.0863E-16   1.5813E-12  -1.3664E-15   1.5800E-12
Total cpu time for bias point =    0.53 minutes
Total cpu time =   20.94 minutes
Slope: 3.032E-01      Device Resistance: 1.467E+14
   V:   77.2320     I: 1.612E-12
   R: 1.000E+07    Va: 7.723E+01
Lte: 7.582E-02    dV: 4.725E+00    dI: 3.221E-14
Solution for Bias:
   V(drain)           =  7.7232010E+01
  XR      1    6.3035E-02  2.0269E+01  1.5536E+02     0
Pass,  Rnorm=5.959E+07   Ratio=1.247E-01   Tdamp=6.667E-01
  XR      2    6.0155E-03  2.5296E+02  2.1762E+01     0
Pass,  Rnorm=1.190E+05   Ratio=1.997E-03   Tdamp=9.698E-01
  XR      3    2.8299E-03  2.0080E+01  9.2499E+00     0
Pass,  Rnorm=3.996E+00   Ratio=3.358E-05   Tdamp=1.000E+00
  XR      4    1.1069E-04  1.3766E+03  3.1787E-01     0
Pass,  Rnorm=9.466E-02   Ratio=2.369E-02   Tdamp=1.000E+00
  XR      5    9.0180E-10  6.8247E+01  2.1317E-02     0
Pass,  Rnorm=7.540E-04   Ratio=7.965E-03   Tdamp=1.000E+00
  XR      6    2.4092E-10  2.0777E-04  6.5922E-03     0
Pass,  Rnorm=2.567E-10   Ratio=3.405E-07   Tdamp=1.000E+00
  XR      7    4.1132E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  1.19148628E-20
gate             0.0000E+00  -6.3162E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0090E-18  -1.6072E-12  -1.6072E-12
drain            7.7232E+01   1.0863E-16   1.6086E-12  -1.3833E-15   1.6072E-12
Total cpu time =   21.46 minutes
Slope: 2.713E-01      Device Resistance: 1.717E+14
   V:   82.3069     I: 1.637E-12
   R: 1.000E+07    Va: 8.231E+01
Lte: 7.582E-02    dV: 5.075E+00    dI: 2.956E-14
Solution for Bias:
   V(drain)           =  8.2306944E+01
  XR      1    7.1950E-02  1.2344E+02  1.0188E+01     0
Pass,  Rnorm=3.142E+08   Ratio=1.260E-01   Tdamp=6.667E-01
  XR      2    1.3167E-02  1.2269E+02  1.8453E+00     0
Pass,  Rnorm=9.084E+05   Ratio=2.891E-03   Tdamp=9.695E-01
  XR      3    3.3277E-03  1.7611E+02  1.4976E+00     0
Pass,  Rnorm=6.901E+00   Ratio=7.597E-06   Tdamp=1.000E+00
  XR      4    1.1683E-04  6.2878E+01  8.2734E-02     0
Pass,  Rnorm=5.607E-02   Ratio=8.125E-03   Tdamp=1.000E+00
  XR      5    7.1393E-10  2.2083E+02  1.5488E-02     0
Pass,  Rnorm=7.461E-04   Ratio=1.331E-02   Tdamp=1.000E+00
  XR      6    2.2020E-10  1.5880E-04  5.2942E-03     0
Pass,  Rnorm=9.953E-11   Ratio=1.334E-07   Tdamp=1.000E+00
  XR      7    4.3959E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  4.02128721E-17
gate             0.0000E+00  -6.5592E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0091E-18  -1.6326E-12  -1.6326E-12
drain            8.2307E+01   1.0863E-16   1.6340E-12  -1.3884E-15   1.6326E-12
Total cpu time for bias point =    0.75 minutes
Total cpu time =   22.21 minutes
Slope: 2.403E-01      Device Resistance: 2.033E+14
   V:   87.7544     I: 1.659E-12
   R: 1.000E+07    Va: 8.775E+01
Lte: 7.434E-02    dV: 5.447E+00    dI: 2.679E-14
Solution for Bias:
   V(drain)           =  8.7754432E+01
  XR      1    8.0580E-02  5.0105E+01  7.1586E+01     0
Pass,  Rnorm=1.820E+09   Ratio=9.120E-01   Tdamp=6.667E-01
  XR      2    1.2089E-02  7.2729E+01  5.7098E+01     0
Pass,  Rnorm=3.818E+08   Ratio=2.098E-01   Tdamp=8.143E-01
  XR      3    3.1189E-03  1.4483E+01  5.1104E+02     0
Pass,  Rnorm=8.278E+05   Ratio=2.168E-03   Tdamp=9.766E-01
  XR      4    5.4890E-04  8.9767E+01  2.2793E-01     0
Pass,  Rnorm=2.429E-01   Ratio=2.934E-07   Tdamp=1.000E+00
  XR      5    3.8819E-10  1.3197E+02  4.1169E-03     0
Pass,  Rnorm=2.643E-02   Ratio=1.088E-01   Tdamp=1.000E+00
  XR      6    5.5033E-10  3.0749E-01  1.2842E-02     0
Pass,  Rnorm=1.212E-08   Ratio=4.587E-07   Tdamp=1.000E+00
  XR      7    1.7408E-13  0.0000E+00  3.9393E-06     0
Using solution any way.  3.02751344E-18
gate             0.0000E+00  -6.8173E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0155E-18  -1.6560E-12  -1.6560E-12
drain            8.7754E+01   1.0863E-16   1.6573E-12  -1.3178E-15   1.6560E-12
Total cpu time =   22.82 minutes
Slope: 2.147E-01      Device Resistance: 2.391E+14
   V:   93.5933     I: 1.680E-12
   R: 1.000E+07    Va: 9.359E+01
Lte: 7.243E-02    dV: 5.839E+00    dI: 2.442E-14
Solution for Bias:
   V(drain)           =  9.3593362E+01
  XR      1    8.7267E-02  6.7840E+01  1.6500E+02     0
Fail,  Rnorm=9.207E+09   Ratio=4.667E+00   Tdamp=6.667E-01
Pass,  Rnorm=1.109E+09   Ratio=5.622E-01   Tdamp=1.667E-01
  XR      2    1.6499E-02  3.3220E+02  1.0771E+03     0
Pass,  Rnorm=5.120E+08   Ratio=4.616E-01   Tdamp=4.157E-01
  XR      3    1.2388E-02  2.7596E+03  1.8188E+00     0
Pass,  Rnorm=1.145E+08   Ratio=2.237E-01   Tdamp=7.550E-01
  XR      4    6.3908E-03  2.3254E+03  1.0016E+00     0
Pass,  Rnorm=4.878E+06   Ratio=4.259E-02   Tdamp=9.650E-01
  XR      5    1.6777E-03  2.0262E+03  9.5849E-01     0
Pass,  Rnorm=3.855E+02   Ratio=7.903E-05   Tdamp=1.000E+00
  XR      6    2.5393E-05  6.6281E+01  3.1021E-02     0
Pass,  Rnorm=3.795E-03   Ratio=9.844E-06   Tdamp=1.000E+00
  XR      7    3.6881E-10  1.0817E+00  8.6520E-03     0
Pass,  Rnorm=7.660E-08   Ratio=2.019E-05   Tdamp=1.000E+00
  XR      8    4.7372E-11  9.0881E-06  7.5051E-06     0
Pass,  Rnorm=3.095E-10   Ratio=4.040E-03   Tdamp=1.000E+00
  XR      9    1.9674E-14  0.0000E+00  0.0000E+00     0
Using solution any way.  5.07775896E-25
gate             0.0000E+00  -7.0873E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0185E-18  -1.7057E-12  -1.7057E-12
drain            9.3593E+01   1.0864E-16   1.6802E-12   2.5491E-14   1.7057E-12
Total cpu time for bias point =    0.69 minutes
Total cpu time =   23.51 minutes
Slope: 4.589E-01      Device Resistance: 1.158E+14
   V:   96.8502     I: 1.734E-12
   R: 1.000E+07    Va: 9.685E+01
Lte: 1.389E-01    dV: 3.257E+00    dI: 2.813E-14
Solution for Bias:
   V(drain)           =  9.6850186E+01
  XR      1    1.4976E-01  1.8479E+01  1.5328E+01     0
Pass,  Rnorm=2.001E+06   Ratio=1.141E-01   Tdamp=6.667E-01
  XR      2    3.5931E-02  2.2596E+02  5.6456E-01     0
Pass,  Rnorm=1.814E+03   Ratio=9.065E-04   Tdamp=9.723E-01
  XR      3    1.0205E-02  2.2991E+02  4.8732E-01     0
Pass,  Rnorm=2.898E-02   Ratio=1.597E-05   Tdamp=1.000E+00
  XR      4    5.5437E-09  1.8097E-01  7.2602E-02     0
Pass,  Rnorm=3.118E-05   Ratio=1.076E-03   Tdamp=1.000E+00
  XR      5*   8.5219E-12  4.0631E-04  1.1091E-04     0
Pass,  Rnorm=2.741E-07   Ratio=8.789E-03   Tdamp=1.000E+00
  XR      6*   4.1745E-16  8.6018E-09  7.8575E-08     0
Pass,  Rnorm=5.540E-10   Ratio=2.021E-03   Tdamp=1.000E+00
  XR      7    6.0399E-17  0.0000E+00  0.0000E+00     0
gate             0.0000E+00  -7.2401E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0263E-18  -3.0526E-12  -3.0526E-12
drain            9.6850E+01   1.0864E-16   1.6881E-12   1.3645E-12   3.0526E-12
Total cpu time for bias point =    0.38 minutes
Total cpu time =   23.89 minutes
Slope: 1.655E+01      Device Resistance: 1.885E+12
   V:   97.0249     I: 3.145E-12
   R: 1.000E+07    Va: 9.702E+01
Lte: 1.016E-01    dV: 1.747E-01    dI: 9.270E-14
Solution for Bias:
   V(drain)           =  9.7024883E+01
  XR      1    1.9574E-08  2.3778E-02  1.5993E-01     0
Pass,  Rnorm=4.758E-04   Ratio=7.848E-05   Tdamp=1.000E+00
  XR      2    1.5009E-11  1.1532E-04  5.6415E-03     0
Pass,  Rnorm=2.313E-07   Ratio=4.861E-04   Tdamp=1.000E+00
  XR      3*   8.6346E-15  2.3028E-08  5.6330E-07     0
Pass,  Rnorm=1.882E-10   Ratio=8.138E-04   Tdamp=1.000E+00
  XR      4    4.0609E-17  0.0000E+00  0.0000E+00     0
gate             0.0000E+00  -7.2487E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0275E-18  -3.3354E-12  -3.3354E-12
drain            9.7025E+01   1.0864E-16   1.6881E-12   1.6473E-12   3.3354E-12
Total cpu time for bias point =    0.23 minutes
Total cpu time =   24.13 minutes
Slope: 4.912E+01      Device Resistance: 5.916E+11
   V:   97.1880     I: 3.611E-12
   R: 1.000E+07    Va: 9.719E+01
Lte: 4.285E-03    dV: 1.632E-01    dI: 2.758E-13
Solution for Bias:
   V(drain)           =  9.7188038E+01
  XR      1    3.7972E-09  2.4344E-03  1.2851E-02     0
Pass,  Rnorm=2.639E-08   Ratio=9.048E-07   Tdamp=1.000E+00
  XR      2    1.2990E-13  1.2830E-06  9.5730E-06     0
Using solution any way.  3.08267911E-14
gate             0.0000E+00  -7.2567E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0249E-18  -3.6480E-12  -3.6480E-12
drain            9.7188E+01   1.0864E-16   1.6880E-12   1.9600E-12   3.6480E-12
Total cpu time for bias point =    0.15 minutes
Total cpu time =   24.28 minutes
Slope: 5.932E+01      Device Resistance: 4.487E+11
   V:   97.5559     I: 4.468E-12
   R: 1.000E+07    Va: 9.756E+01
Lte: 3.705E-04    dV: 3.679E-01    dI: 8.199E-13
Solution for Bias:
   V(drain)           =  9.7555952E+01
  XR      1    1.0251E-08  9.0323E-03  3.8487E-02     0
Pass,  Rnorm=5.471E-06   Ratio=2.239E-06   Tdamp=1.000E+00
  XR      2    1.7154E-12  2.0208E-05  9.1357E-05     0
Pass,  Rnorm=1.894E-10   Ratio=3.461E-05   Tdamp=1.000E+00
  XR      3*   1.5283E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  1.69140906E-15
gate             0.0000E+00  -7.2747E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0262E-18  -4.5680E-12  -4.5680E-12
drain            9.7556E+01   1.0864E-16   1.6875E-12   2.8805E-12   4.5680E-12
Total cpu time for bias point =    0.16 minutes
Total cpu time =   24.44 minutes
Slope: 6.811E+01      Device Resistance: 3.129E+11
   V:   98.4293     I: 7.359E-12
   R: 1.000E+07    Va: 9.843E+01
Lte: 1.607E-03    dV: 8.733E-01    dI: 2.791E-12
Solution for Bias:
   V(drain)           =  9.8429330E+01
  XR      1    1.2734E-07  5.3910E-02  1.4001E-01     0
Pass,  Rnorm=2.008E-03   Ratio=2.660E-05   Tdamp=1.000E+00
  XR      2    5.9122E-11  9.3144E-04  3.7362E-03     0
Pass,  Rnorm=3.708E-07   Ratio=1.847E-04   Tdamp=1.000E+00
  XR      3*   3.4643E-14  3.2158E-08  6.5417E-07     0
Pass,  Rnorm=2.881E-10   Ratio=7.769E-04   Tdamp=1.000E+00
  XR      4    1.2806E-17  0.0000E+00  0.0000E+00     0
gate             0.0000E+00  -7.3180E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0275E-18  -8.6128E-12  -8.6128E-12
drain            9.8429E+01   1.0864E-16   1.6842E-12   6.9286E-12   8.6128E-12
Total cpu time =   24.67 minutes
Slope: 8.268E+01      Device Resistance: 1.376E+11
   V:  100.3975     I: 2.292E-11
   R: 1.000E+07    Va: 1.004E+02
Lte: 4.056E-03    dV: 1.968E+00    dI: 1.430E-11
Solution for Bias:
   V(drain)           =  1.0039770E+02
  XR      1    8.9765E-04  5.7268E-01  1.4652E+00     0
Pass,  Rnorm=3.626E-01   Ratio=9.601E-06   Tdamp=1.000E+00
  XR      2    7.6248E-10  4.6468E-02  1.1336E-02     0
Pass,  Rnorm=9.560E-04   Ratio=2.636E-03   Tdamp=1.000E+00
  XR      3*   2.2144E-10  7.2811E-05  6.2742E-03     0
Pass,  Rnorm=2.090E-07   Ratio=2.186E-04   Tdamp=1.000E+00
  XR      4    8.4303E-12  1.9876E-06  6.3504E-05     0
Pass,  Rnorm=1.328E-10   Ratio=6.356E-04   Tdamp=1.000E+00
  XR      5*   7.8504E-16  0.0000E+00  0.0000E+00     0
Using solution any way.  4.43736786E-14
gate             0.0000E+00  -7.4163E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0319E-18  -4.4296E-11  -4.4296E-11
drain            1.0040E+02   1.0864E-16   1.6638E-12   4.2632E-11   4.4296E-11
Total cpu time for bias point =    0.24 minutes
Total cpu time =   24.90 minutes
Slope: 8.972E+01      Device Resistance: 2.501E+10
   V:  103.8935     I: 1.841E-10
   R: 1.000E+07    Va: 1.039E+02
Lte: 1.338E-02    dV: 3.496E+00    dI: 1.398E-10
Solution for Bias:
   V(drain)           =  1.0389538E+02
  XR      1    2.6638E-04  9.2401E+00  8.8975E+00     0
Pass,  Rnorm=6.143E+02   Ratio=6.082E-06   Tdamp=1.000E+00
  XR      2    4.6984E-08  2.0988E+00  1.5099E-01     0
Pass,  Rnorm=2.874E-03   Ratio=4.678E-06   Tdamp=1.000E+00
  XR      3    1.4691E-10  5.0201E-02  3.3152E-03     0
Pass,  Rnorm=3.420E-07   Ratio=1.190E-04   Tdamp=1.000E+00
  XR      4*   2.6431E-13  6.2448E-08  0.0000E+00     0
Using solution any way.  3.76665077E-11
gate             0.0000E+00  -7.5908E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.0403E-18  -6.8947E-10  -6.8947E-10
drain            1.0389E+02   1.0863E-16   1.5926E-12   6.8788E-10   6.8947E-10
Total cpu time =   25.13 minutes
Slope: 7.934E+01      Device Resistance: 1.867E+09
   V:  109.1044     I: 3.483E-09
   R: 1.000E+07    Va: 1.091E+02
Lte: 3.273E-02    dV: 5.216E+00    dI: 2.793E-09
Solution for Bias:
   V(drain)           =  1.0913921E+02
  XR      1    2.1928E-01  5.0871E+00  2.2944E+01     0
Pass,  Rnorm=4.333E+15   Ratio=1.293E-01   Tdamp=6.667E-01
  XR      2    6.1759E-02  5.8590E+01  7.0668E+02     0
Pass,  Rnorm=2.302E+13   Ratio=5.312E-03   Tdamp=9.687E-01
  XR      3    5.5941E-02  3.1175E+00  1.0015E+00     0
Pass,  Rnorm=4.300E+10   Ratio=1.868E-03   Tdamp=9.950E-01
  XR      4    3.1185E-03  1.3533E+00  4.1737E-02     0
Pass,  Rnorm=2.628E+03   Ratio=6.111E-08   Tdamp=1.000E+00
  XR      5    5.0931E-05  1.0027E+00  2.0806E-03     0
Pass,  Rnorm=6.973E-04   Ratio=2.653E-07   Tdamp=1.000E+00
  XR      6    6.0248E-09  3.0049E+00  2.3528E-09     0
Pass,  Rnorm=7.941E-10   Ratio=1.139E-06   Tdamp=1.000E+00
  XR      7    1.5395E-10  0.0000E+00  0.0000E+00     0
Using solution any way.  3.49680861E-18
gate             0.0000E+00  -7.8457E-15   0.0000E+00   0.0000E+00   0.0000E+00
source           0.0000E+00  -1.1959E-17  -7.1471E-18  -1.6595E-08  -1.6595E-08
drain            1.0897E+02   1.0866E-16   2.4415E-12   1.6592E-08   1.6595E-08
Total cpu time for bias point =    0.50 minutes
Total cpu time =   25.64 minutes
Slope: 5.990E+01      Device Resistance: 1.071E+08
   V:  108.9733     I: 1.659E-08
Lte: 6.275E-02    dV: 1.777E-07    dI: 1.659E-15
  Previous solution used as initial guess.
58 Points   4 Failed  0 Cut.
Solution for Bias:
   V(drain)           =  1.0913922E+02
  XR      1    1.5975E-09  0.0000E+00  0.0000E+00     0
Using solution any way.  7.67770585E-18
source           0.0000E+00  -1.1959E-17  -7.1467E-18  -1.6595E-08  -1.6595E-08
发表于 2010-7-29 18:38:12 | 显示全部楼层
不好意思,搞错了
发表于 2010-8-10 04:48:47 | 显示全部楼层
Thanks!
发表于 2010-8-10 04:50:18 | 显示全部楼层
Thanks!
发表于 2010-8-10 04:52:38 | 显示全部楼层
Thanks!
发表于 2010-8-10 04:53:06 | 显示全部楼层
感谢分享
GMT+8, 2025-12-3 20:10 , Processed in 0.029244 second(s), 3 queries , Gzip On, Redis On.
