查看: 7566|回复: 22
MillerCompensation Using CurrentBuffer in Differential CMOS OP Amplifier
发表于 2006-9-14 21:30:30 | 显示全部楼层 |阅读模式
Abstract—Several Miller compensation schemes using a current buffer in series with the compensation capacitor to modify the right-half-plane zero in fully differential two-stage CMOS operational amplifiers are analyzed. One scheme uses a current mirror as a current buffer, while the rest use a common-gate transistor as a current buffer. The gain transfer functions are derived for each
topology, and approximate transfer-function coefficients are found that allow accurate estimation of the zero(s) and poles.
abbr_g Current Buffer in Fully Differential CMOS Two-Stage Operational Amplifiers.pdf
326.2 KB, 下载次数: 280 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-15 01:13:56 | 显示全部楼层
顶以下
发表于 2006-9-17 07:37:08 | 显示全部楼层
good book
发表于 2006-9-17 20:30:33 | 显示全部楼层
thanks a lot!!
发表于 2006-9-17 20:33:06 | 显示全部楼层
paper 下来看看。。
发表于 2007-6-5 15:09:26 | 显示全部楼层
正在找关于电流amp的资料,谢lz
发表于 2007-6-6 00:17:34 | 显示全部楼层
ding!!!
发表于 2007-6-6 09:47:16 | 显示全部楼层
Very Good Job!
发表于 2007-10-16 14:12:21 | 显示全部楼层
好文章!
发表于 2007-11-29 23:18:18 | 显示全部楼层
push~~~~~
GMT+8, 2025-12-22 19:03 , Processed in 0.027677 second(s), 6 queries , Gzip On, Redis On.
