查看: 6912|回复: 17
Problem with Cadence EXT9.1.2(Please help)
发表于 2010-6-7 01:09:31 | 显示全部楼层 |阅读模式
Hi friends,
I'm using RedHat5.4 i ve installed cadence Ext9.1.2 without any problems and also cracked it. i ve done what vanduongbk
said about the crack and the patch.
the problem is : in the terminal the Ext9.1.2 is checked out but when i would like to use QRC under virtuoso i have a message as you can see in the picture:
As you can see DFM_Core_Technology is checked out under the terminal but no in Virtuoso, so what should i do to solve this problem
Thanks in Advance
 楼主| 发表于 2010-6-7 04:42:59 | 显示全部楼层
plz help
发表于 2010-6-7 08:36:20 | 显示全部楼层
where is the picture?
 楼主| 发表于 2010-6-7 13:54:59 | 显示全部楼层
yulizi 发表于 2010-6-7 08:36
The picture is in the post
 楼主| 发表于 2010-6-7 16:56:59 | 显示全部楼层
plz help
 楼主| 发表于 2010-6-8 04:10:23 | 显示全部楼层
urgent help
 楼主| 发表于 2010-6-9 02:06:30 | 显示全部楼层
i got to work at home and do a report please help
发表于 2010-6-9 08:08:20 | 显示全部楼层
Please check your license file whether you have the DFM_Core_Technology feature or not.
If not, please add in.
 楼主| 发表于 2010-6-9 19:22:27 | 显示全部楼层
SamsungMonitor 发表于 2010-6-9 08:08
I've got this
3:53:36 (cdslmd) UNSUPPORTED: "DFM_Core_Technology" (PORT_AT_HOST_PLUS   ) theshadowx@*****  (License server system does not support this feature. (-18,327))
What do you think i should do
发表于 2010-6-30 16:49:45 | 显示全部楼层
this is very strange, let me think about it.  I will find you a solution soon
GMT+8, 2025-12-22 02:12 , Processed in 0.027808 second(s), 6 queries , Gzip On, Redis On.
