楼主: gman
Crack: ModelSim 6.6a
发表于 2010-6-20 12:47:04 | 显示全部楼层
thank you
发表于 2010-6-20 14:36:38 | 显示全部楼层
替楼主说明一下怎么用,请注意 -h的option,这个后面要接你要用的网卡的mac地址。楼主的rar文件的MakeLic.bat里用的是你windows,运行这个机器的mac地址,但是大家很多人是装在linux上的,就不能简单运行这个bat文件了,你得会修改。
Mentor Graphics MGCLD License KeyGen V8.0
?2010 by Team EFA (Eda For All).
usage: MentorKG [licensefile(s)] [-options]
   licensefile(s) is(are) the file(s) to recrypt
   options:
   -i infile   , defines the INPUT file.
   -o outfile  , defines the OUTPUT file.
   -e errfile  , defines the ERROR file otherwise goes to stdout.
   -h HostID   , default is one of your Network Cards
                 X-YYYYYYYY   gives HOSTID=FLEXID=X-YYYYYYYY
                 XXXXXXXXXXXX gives HOSTID=XXXXXXXXXXXX
   -hn         , uses the NETWORK CARD as host
   -hd         , uses the DISK_SERIAL_NUM as host
   -h7         , uses the FlexID=7-xxxxxxxx as host
   -h6         , uses the FlexID=6-xxxxxxxx as host
   -n          , forces the license to be Nodelocked (Default).
   -f          , forces the license to be FLOATING.
   -u          , number of users in case of floating Defaults to 99.
   -sn         , serial number to be used in license, generates a random by defa
ult
   -pack       , makes license using PACKAGE
   -all        , makes license using ALL known features
   -perm       , makes a PERMANENT license
   -exp m/d/y  , sets the license expiration date, default is 7 years from today
   -notice str , Changes NOTICE= to str, if null clears and with spaces use "str
   -issuer str , Changes ISSUER= to str, same as notice
   -s          , Takes out SUPERSEDE from license
   -ck         , Disables Checksum of license
   -none       , Disables NOTICE,ISSUER and ck
   -x          , bypasses any parsing of license, just recrypt
   -maxlen n   , limits line length for continuation, -1 for unlimited.
   -longkey    , includes generation date in the KEY (default).
   If no arguments, generates a default LICENSE.TXT in current folder.
   Examples:
   MentorKG -o TEST.DAT             ; Makes a default TEST.DAT
   MentorKG License.dat -efa -maxlen -1  ; Recrypts License.dat no warp lines
   Host examples:
   MentorKG -h 6-12345678       ; Nodelocked HOSTID=FLEXID=6-12345678.
   MentorKG -f -h ffffffff      ; Floating HOSTID=ffffffff (works fine also).
发表于 2010-6-21 14:37:42 | 显示全部楼层
好,试试,非常感谢!
发表于 2010-6-22 11:25:54 | 显示全部楼层
发表于 2010-6-24 10:24:33 | 显示全部楼层
这个可以用~~~~~~
发表于 2010-6-24 11:00:50 | 显示全部楼层
Thanks...
发表于 2010-6-24 16:53:08 | 显示全部楼层
还是用不了,打开后报错"unable to checkout a viewer license necessary for use of the modelsim graphical user interface.Vsim is closing",我是在windows下用的
发表于 2010-6-24 22:44:08 | 显示全部楼层
还得重新下一次~~~
发表于 2010-6-26 11:32:58 | 显示全部楼层
谢谢 正在找这个
发表于 2010-6-26 16:32:55 | 显示全部楼层
顶啊,终于找到破解了
GMT+8, 2025-10-29 20:17 , Processed in 0.015804 second(s), 3 queries , Gzip On, Redis On.
