查看: 1971|回复: 1
[原创] Circuit Cellar #239 June 2010
发表于 2010-6-1 19:47:29 | 显示全部楼层 |阅读模式
Issue #239 June 2010 — Communications
◊ OAE Probe Amp and Intercom (Part 2): Otoacoustic Experiments
◊ Home Automation for an Energy-Efficient House (Part 2): Embedded CANOpen Node Hardware & Software
◊ Custom Interpreter Development: An Innovative LED Movie Project
◊ THE DARKER SIDE DC/DC Converter Basics
◊ ABOVE THE GROUND PLANE Totally Featureless WWVB Clock (Part 3): Signal Processing
◊ FROM THE BENCH Application Communication with USB (Part 1): The Enumeration Process Explained
◊ SILICON UPDATE Ditch the Switch?
http://ifile.it/h02rokg/CCJ.zip
发表于 2010-6-5 01:39:55 | 显示全部楼层
thanks
GMT+8, 2025-12-3 16:41 , Processed in 0.018660 second(s), 6 queries , Gzip On, Redis On.
