楼主: qiongjian
[原创] 射频PDK发布,SMIC0.13RF工艺
发表于 2011-4-11 19:18:43 | 显示全部楼层
thanks!
发表于 2011-4-12 09:39:52 | 显示全部楼层
***0.13um Mixed Signal 1P8M with MIM Salicide 1.2V/2.5V Process***
*** For SPECTRE only ***
Files:
      ms013_rf_readme_v1p4_spe.txt     .... This file!
      ms013_rf_v1p4_spe.lib            .... Corner values for resistors and MIM
      ms013_rf_mos_v1p4_spe.ckt        .... Subcircuit model of RF MOS
      ms013_rf_spir_ind_v1p4_spe.ckt        .... Subcircuit model of spiral inductor
      ms013_rf_diff_ind_v1p4_spe.ckt        .... Subcircuit model of differential inductor
      ms013_rf_mim_v1p4_spe.ckt        .... Subcircuit model of MIM
      ms013_rf_var_v1p4_spe.ckt        .... Subcircuit model of varactor
      ms013_rf_res_v1p4_spe.ckt        .... Subcircuit model of sab resistor
      res_rf.va                       .... Resistor modules
      ms013_rf_interconnect_struct_1.txt   .... Interconnect tables for structure-1 (Parallel lines above a bottom plate)
      ms013_rf_interconnect_struct_2.txt   .... Interconnect tables for structure-2 (Parallel lines between two plates)
      ms013_rf_layer.map                   .... GDSII layers definition file
      N12_W2d5Ld13N32.gds                  .... GDSII file for 1.2V NMOS W/L/N=2.5/0.13/32
      P12_W2d5Ld13N32.gds                  .... GDSII file for 1.2V PMOS W/L/N=2.5/0.13/32
      N25_W2d5Ld285N32.gds                 .... GDSII file for 2.5V NMOS W/L/N=2.5/0.28/32
      P25_W2d5Ld280N32.gds                 .... GDSII file for 2.5V PMOS W/L/N=2.5/0.28/32
      SPIR_IND_W8S1d5R60N3d5.gds                .... GDSII file for Spiral Inductor W/S/R/N=8/1.5/60/3.5
      DIFF_IND_W8S1D5R60N3.gds                .... GDSII file for Differential Inductor W/S/R/N=8/1.5/60/3
      VAR12_MOS_W10L1N8.gds                .... GDSII file for MOS Varactor W/L/N=10/1/8
      VAR25_MOS_W10L1N8.gds                .... GDSII file for MOS Varactor W/L/N=10/1/8
      VAR12_JUN_W1L20N20.gds               .... GDSII file for Varactor Junction Diode W/L/N=1/20/20
      VAR25_JUN_W1L20N20.gds               .... GDSII file for Varactor Junction Diode W/L/N=1/20/20
      MIM_10x10.gds                        .... GDSII file for MIM Area=10*10
      RNDIFSAB_W2L40.gds                   .... GDSII file for Non-silicide N+ Diffusion Resistor W/L=2/40
      RPDIFSAB_W2L40.gds                   .... GDSII file for Non-silicide P+ Diffusion Resistor W/L=2/40
      RNPOSAB_W2L40.gds                    .... GDSII file for Non-silicide N+ Poly Resistor W/L=2/40
      RPPOSAB_W2L40.gds                    .... GDSII file for Non-silicide P+ Poly Resistor W/L=2/40
      SUB_PP_100.gds                             .... GDSII file for P+AA within floating P+ guard ring in Pwell for spacing=100um substrate coupling noise
      SUB_PP_FGR_100.gds                   .... GDSII file for P+AA within floating P+ guard ring in Pwell for spacing=100um substrate coupling noise
      SUB_PDNWP_100.gds                    .... GDSII file for P+AA in floating Deep Nwell to P+AA in Pwell with spacing=100um substrate coupling noise
      SUB_NNMOSDNW_100.gds           .... GDSII file for NMOS in floating Deep Nwell to NMOS in floating Deep Nwell with spacing=100um substrate coupling noise
      SUB_NFGRP_100.gds                    .... GDSII file for N+AA within P+ guard ring to P+AA in Pwell with spacing=100um substrate coupling noise
How to use SMIC SPICE models in SPECTRE :
   ** Load model cards and select corner
   include "ms013_rf_v1p4_spe.lib" section=mos_tt
   include "ms013_rf_v1p4_spe.lib" section=mim_tt
   include "ms013_rf_v1p4_spe.lib" section=res_tt
   include "ms013_rf_spir_ind_v1p4_spe.ckt"
   include "ms013_rf_diff_ind_v1p4_spe.ckt"
   include "ms013_rf_var_v1p4_spe.ckt"
   ** Call the models
    XM (1 2 0 0) n12_ckt_rf lr=0.13u wr=2.5u nf=16
    X1 (1 2) ind_rf r=60u n=3.5
    X2 (1 2) diff_ind_rf r=60u n=3
    X3 (1 2) mim1_rf lr=10u wr=10u
    X4 (1 2) pvar25_ckt_rf wr=10u lr=1u nf=16
    X5 (1 2) pvardio12_ckt_rf wr=1u lr=20u nf=20
    X6 (1 2) rpdifsab_ckt_rf l=40u w=2u
Corner Model:
      MOS        name : corner
                 mos_tt : Typical case
                 mos_ff : Fast case
                 mos_ss : Slow case
                 mos_fnsp : Fast N Slow P case
                 mos_snfp : Slow N Fast P case
      Resistor   name : corner
                 res_tt : Typical case
                 res_ff : Fast case
                 res_ss : Slow case
      MIM  name : corner
                 mim_tt : Typical case
                 mim_ff : Fast case
                 mim_ss : Slow case
发表于 2011-4-17 12:06:06 | 显示全部楼层
多谢多谢
发表于 2011-4-20 14:43:01 | 显示全部楼层
真的感谢楼主~~太有用咯
发表于 2011-4-20 19:31:30 | 显示全部楼层
东西太好了~~
发表于 2011-4-21 23:40:39 | 显示全部楼层
多谢楼主分享
发表于 2011-5-5 11:12:48 | 显示全部楼层
只是CDB不是OA么??
发表于 2011-5-7 14:21:38 | 显示全部楼层
谢谢啊
发表于 2011-5-7 14:55:39 | 显示全部楼层
居然要10分一个,怎么回事啊?晕
发表于 2011-5-7 15:01:53 | 显示全部楼层
实在是太贵了啊
GMT+8, 2025-11-7 05:19 , Processed in 0.020004 second(s), 4 queries , Gzip On, Redis On.
