查看: 1920|回复: 1
[招聘] NO.152-Analog Design Engineer 3G MULTIMEDIA & PLATFORMS(Shanghai)
发表于 2010-5-26 14:49:46 | 显示全部楼层 |阅读模式
Job Description
As an Analog Design Engineer you are a member of our PMU design team. You will be developing analog IP and analog blocks for power management IC. You play an important role in the mixed signal integrated circuits design. The role will cover the full IC design cycle from specification through to testing of engineering samples.
Key Areas of Responsibility
1. Carry out development activities from design, verification to physical validation for mixed signal integrated circuits (Analog, power and digital blocks) for power management IC;
2. Interface with layout team, performing or providing guidance for layout design and controlling layout design and work quality;
3. Evaluate the product with application team to meet customer specification;
4. Debug product to fix incorrect operation and meet customer specification;
5. Work with a project leader to identify tasks and track progress to plan;
6. Work with an architect to define block specification, simulation, verification and physical validation plan;
7. Work with other team members to build up design knowledge and improve way of working;
8. Develop his/her leadership on his/her domain of skills and actions.
Requirements
1. BSEE with minimum of 6 years or MSEE with minimum of 2 years analog design experience;
2. Experience designing any or all of the following: DCDC, Charge pump, LDO, amplifier and comparator;
3. Familiar with CAD tools and environments, i.e., design workstations and UNIX; Familiar with Cadence Spectre, Virtuoso Layout XL;
4. Experience in analog layout design and physical validation;
5. Good command of English;
6. Good team-worker with a pro-active attitude;
7. Experience in PCB design, instrument and measurement, lab skills, and lab evaluation is a plus.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: winni-cao@kthr.com, thanks!
发表于 2010-6-10 18:53:39 | 显示全部楼层
xiexie
GMT+8, 2025-12-23 12:09 , Processed in 0.015170 second(s), 5 queries , Gzip On, Redis On.
