楼主: theshadowx
[request] Cadence EXT091.lnx86.base (urgent)
发表于 2010-5-25 07:29:00 | 显示全部楼层
you can make some screenshot about your QRC/RCX :both setup and run QRC
I will help you
发表于 2010-5-25 07:40:11 | 显示全部楼层
you see *WARNING* Technology must be specified! in your log file
 楼主| 发表于 2010-5-25 13:24:32 | 显示全部楼层
ok thanks
now i loaded the technology but i got this in log file
Loading tech rule set file : /home/theshadowx/EDA/Dkits/Ams/4.00/assura/c35b4/c35b4c3/techRuleSets
Loading all available p-cell functions
AMS_DB set to cds
No mx check
INFO (LBRCXU-114): Finished /home/theshadowx/EDA/Cadence/Assura_4.10/tools/assura/bin/rcxToDfII
INFO (LBRCXM-642): Constructing the RCX run script
INFO (LBMISC-215205):
*** Cadence Extraction QRC Techgen -trans VERSION 7.1 Linux 32 bit - (Wed Nov 28 05:33:58 PST 2007)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /home/theshadowx/workspace/ProjetP4/ASSURA_LVS
ERROR (LBMISC-215479): at "Techgen -trans": Connect layer 'net_nwell' from lvsfile is declared as stamped layer in p2lvsfile. Please check the p2lvsfile.
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
/home/theshadowx/EDA/Cadence/EXT710/tools.lnx86/extraction/bin/32bit//capgen -techdir /home/theshadowx/EDA/Dkits/Ams/4.00/assura/c35b4/c35b4c3/RCX-typical -lvs /home/theshadowx/workspace/ProjetP4/ASSURA_LVS.xcn -p2lvs /home/theshadowx/EDA/Dkits/Ams/4.00/assura/c35b4/c35b4c3/RCX-typical/p2lvsfile -length_units meters -cap_unit 1.0 -selected_paths_proper -p poly1,capgen_gate,diffusion -no_cap_correction -cap_ground_layer net_psub -dsub net_nwell,net_psub -lexclude poly2,poly1 -blocking CPOLY_PSUB_device:1.8,poly2,poly1 -blocking CPOLY_NTUB_device:1.8,poly2,poly1 -blocking CPOLYRF_device,met1,poly2,poly1,diffusion,fox -blocking CMIM_device:1,met2cap,met2 -blocking RPOLY2RF_device,met1,poly2,poly1,diffusion,fox -blocking NMOSRF_device,met1,poly1,diffusion,fox -blocking PMOSRF_device,met1,poly1,diffusion,fox -res_blocking rblock_poly1,net_poly1 -res_blocking rblock_poly2,net_poly2 -res_blocking rblock_met1,net_met1 -res_blocking rblock_met2,net_met2 -res_blocking rblock_met3,net_met3 -res_blocking rblock_met4,net_met4 -sw3d /home/theshadowx/workspace/ProjetP4/ASSURA_LVS
Forking:  /home/theshadowx/EDA/Cadence/EXT710/tools.lnx86/extraction/bin/32bit//capgen -techdir /home/theshadowx/EDA/Dkits/Ams/4.00/assura/c35b4/c35b4c3/RCX-typical -lvs /home/theshadowx/workspace/ProjetP4/ASSURA_LVS.xcn -p2lvs /home/theshadowx/EDA/Dkits/Ams/4.00/assura/c35b4/c35b4c3/RCX-typical/p2lvsfile -length_units meters -cap_unit 1.0 -selected_paths_proper -p poly1,capgen_gate,diffusion -no_cap_correction -cap_ground_layer net_psub -dsub net_nwell,net_psub -lexclude poly2,poly1 -blocking CPOLY_PSUB_device:1.8,poly2,poly1 -blocking CPOLY_NTUB_device:1.8,poly2,poly1 -blocking CPOLYRF_device,met1,poly2,poly1,diffusion,fox -blocking CMIM_device:1,met2cap,met2 -blocking RPOLY2RF_device,met1,poly2,poly1,diffusion,fox -blocking NMOSRF_device,met1,poly1,diffusion,fox -blocking PMOSRF_device,met1,poly1,diffusion,fox -res_blocking rblock_poly1,net_poly1 -res_blocking rblock_poly2,net_poly2 -res_blocking rblock_met1,net_met1 -res_blocking rblock_met2,net_met2 -res_blocking rblock_met3,net_met3 -res_blocking rblock_met4,net_met4 -sw3d /home/theshadowx/workspace/ProjetP4/ASSURA_LVS
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
发表于 2010-5-25 14:59:10 | 显示全部楼层
first ,you  must run assura LVS complete sucessfully ,no have any error
after you run QRC ,must sure run LVS complete
 楼主| 发表于 2010-5-25 17:09:30 | 显示全部楼层
that s what i ve done, for LVS  there was no error. so then i run QRC and boom error
发表于 2010-5-26 18:46:01 | 显示全部楼层
Here is the EXT9.1.2 (EXT9.1 Update 2).
http://www.eetop.cn/bbs/thread-254191-1-1.html
You can direct install withhout EXT9.1 Base.
发表于 2010-5-26 18:53:36 | 显示全部楼层
thank you
发表于 2010-6-23 00:36:40 | 显示全部楼层
Thanks!!!
发表于 2010-6-23 00:49:38 | 显示全部楼层
thanks
发表于 2010-6-30 14:20:20 | 显示全部楼层
sanks
GMT+8, 2025-9-28 06:50 , Processed in 0.018302 second(s), 5 queries , Gzip On, Redis On.
