查看: 15183|回复: 34
[request] Cadence EXT091.lnx86.base (urgent)
发表于 2010-5-21 03:25:16 | 显示全部楼层 |阅读模式
hi friends
can someone upload Cadence EXT091.lnx86.base  please,
i need it for a project to make extraction of layout
thanks in advance
 楼主| 发表于 2010-5-21 14:06:05 | 显示全部楼层
please guys i need it so much
发表于 2010-5-21 15:46:44 | 显示全部楼层
please guys i need $1000000000000000000000 so much
 楼主| 发表于 2010-5-21 16:13:11 | 显示全部楼层
发表于 2010-5-23 08:16:12 | 显示全部楼层
The latest version for now is EXT9.1.2 (Update 2)... You still want the Base version??
发表于 2010-5-23 08:37:53 | 显示全部楼层
hi SamsungMonitor
you can upload base or update EXT9.1
发表于 2010-5-23 09:00:22 | 显示全部楼层
I can upload those software, but it is pointless if no crack or patch for it. So can somebody kindly share the patch or crack?
Thanks.
发表于 2010-5-23 09:06:43 | 显示全部楼层
I only use cadence EXT 7.1 complete successfully
I dont try to EXT 9.1 or 8.1 because I dont have it
you can upload it
I think that someone can crack it on eetop
 楼主| 发表于 2010-5-23 16:01:18 | 显示全部楼层
thanks guys
ya you re right if there is no crack it's pointless to upload them,
i have downloaded EXT 7.1  and installed but the problem is that i don t get QRC menu in layout window.( i use IC 6.1.4)
at university we use EXT 9.1 with IC 6.1.3 and in the layout menu bar there is
...  ASSURA  QRC  ....
and in the QRC there is -->setup QRC
                                    --> Run QRC
@TSMC  can you tell me the environment variable for EXT7.1
              Do i have to crack it or something like that because i just installed it
                   and do some environment variable
发表于 2010-5-23 20:41:27 | 显示全部楼层
it will integrate with assura 317 or higher
when you run assura on menu ,
inside have run QRC,I use ic613+assura413
or can use standalone  with assura 413
GMT+8, 2025-12-22 22:21 , Processed in 0.141162 second(s), 9 queries , Gzip On, Redis On.
