楼主: theshadowx
[request] Cadence EXT091.lnx86.base (urgent)
发表于 2010-5-23 20:57:42 | 显示全部楼层
this is environment variable for EXT 7.1 in my .bashrc
export QRC_HOME=/home/cadence/EXT71
export QRC_ENABLE_EXTRACTION=""
export PATH=/home/cadence/EXT71/binPATH
anyone can upload cadence EXT 8.1 or 9.1
thank for advange
 楼主| 发表于 2010-5-24 15:10:25 | 显示全部楼层
thanks
 楼主| 发表于 2010-5-24 15:11:43 | 显示全部楼层
i hope SamsungMonitor will upload the latest version or  at least 8.1
发表于 2010-5-24 16:08:38 | 显示全部楼层
hi SamsungMonitor ,you can upload EXT 8.1 or 9.1
Please believe I very need it
发表于 2010-5-24 16:10:26 | 显示全部楼层
发表于 2010-5-24 16:25:56 | 显示全部楼层
I will upload EXT9.1 by this week...
发表于 2010-5-24 16:31:32 | 显示全部楼层
thank SamsungMonitor
I will make cell to download
 楼主| 发表于 2010-5-24 16:40:01 | 显示全部楼层
thanks a lot.
now i m using IC614  with assura4.10 and ext7.1.
i wanna generate the av_extracted but i had this error
Could not open file /home/theshadowx/workspace/ProjetP4/RCXspiceINIT for reading
so what should i do to solve this issue
Cadence Extraction QRC - Parasitic Extractor - Version 7.1.0-p006 Wed Nov
28 05:39:40 PST 2007
                            Copyright 2007 Cadence Design Systems, Inc.
INFO (LBRCXU-108): Starting
/home/theshadowx/EDA/Cadence/Assura_4.10/tools/assura/bin/rcxToDfII /home/theshadowx/workspace/ProjetP4/rcx.Ampli_868.rsf -t -f /home/theshadowx/workspace/ProjetP4/Ampli_868/extview.tmp -w /home/theshadowx/workspace/ProjetP4/Ampli_868 -cdslib /home/theshadowx/workspace/ProjetP4/cds.lib
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.05s.
@(#)$CDS: rcxToDfII version av4.1roduction:dfII6.1.3:IC6.1.3.500.15 11/14/2009 11:50 (vl-sfrh03) $
sub-version 4.1_USR1, integ signature 2009-11-14-1018
run on **** from /home/theshadowx/EDA/Cadence/Assura_4.10/tools.lnx86/assura/bin/32bit/rcxToDfII on Mon May 24 01:02:38 2010
*WARNING* Technology must be specified!
Loading all available p-cell functions
AMS_DB set to cds
No mx check
INFO (LBRCXU-114): Finished /home/theshadowx/EDA/Cadence/Assura_4.10/tools/assura/bin/rcxToDfII
INFO (LBRCXM-642): Constructing the RCX run script
INFO (RCXSPIC-27050): Could not open file /home/theshadowx/workspace/ProjetP4/RCXspiceINIT for reading
发表于 2010-5-24 20:40:24 | 显示全部楼层
don't  you  have technology file ?
you need qrcTechfile
 楼主| 发表于 2010-5-25 01:49:57 | 显示全部楼层
where can i get it
@tsmc
Could you make me some screenshot of your QRC setup please
GMT+8, 2025-9-28 06:50 , Processed in 0.018025 second(s), 5 queries , Gzip On, Redis On.
