查看: 9891|回复: 31
[资料] LCD Driver operational amp
发表于 2010-5-15 13:07:18 | 显示全部楼层 |阅读模式
非常好的设计资料。good!
Aconstant_g_mandhigh__论文_plifierforanLCD.pdf
542.96 KB, 下载次数: 295 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-5-16 02:40:29 | 显示全部楼层
thank you...
发表于 2010-5-16 04:29:45 | 显示全部楼层
thank you
发表于 2010-5-16 13:59:05 | 显示全部楼层
ddddddddddddddddddddddd
发表于 2010-5-16 15:03:22 | 显示全部楼层
very good article
发表于 2010-5-16 15:43:20 | 显示全部楼层
谢谢分享
发表于 2010-5-16 18:25:31 | 显示全部楼层
ding~
发表于 2010-5-16 21:32:56 | 显示全部楼层
thank you ~
发表于 2010-5-16 21:44:16 | 显示全部楼层
thanks~~~
发表于 2010-5-16 22:31:46 | 显示全部楼层
A constant-gm and high-slew-rate operational amplifier for an LCD driver
Lai Xinquan(), Li Xinlin( )†, Ye Qiang(        ), Yuan Bing(
􀀀), and Li Xianrui()
(Institute of Electronic CAD, Xidian University, Xi’an 710071, China)
Abstract: To drive the backplane of a liquid crystal display device and achieve different kinds of grey levels, a
high-slew-rate operational amplifier with constant-gm input stage is presented. A Zener-diode structure is inserted
between the tails of the complementary input pairs to keep the gm of the input stage constant. A novel slew rate
enhancement circuit is implemented to achieve a very high slew rate. The chip has been implemented in a 0.5 μm
CMOS process and the chip area of the operational amplifier circuit is 0.11 mm2. The testing results indicate that in
the 5–8 V input range, the maximum gm fluctuation is only 4.2%. The result exhibits a high slew rate of 111 V/μs
and 102 V/μs for the rising and falling edges under a 20 pF capacitance load, and the low frequency gain is up to
109 dB with a phase margin of 70 C.
Key words: constant-gm; operational amplifier; Zener diode; slew rate
DOI: 10.1088/1674-4926/30/12/125002 EEACC: 1205; 1220
GMT+8, 2025-12-14 23:46 , Processed in 0.025384 second(s), 7 queries , Gzip On, Redis On.
