查看: 2873|回复: 0
请教:行为综合时bc_check_design问题!
发表于 2006-9-10 00:22:21 | 显示全部楼层 |阅读模式
在做行为综合用到检查设计命令bc_check_design时,出现以下ERROR:
   Information:Checking for reset loop coding style will be performed on the reset loop.
   Error:There must be a main(infinite) loop inside the reset loop,if you are using the direct
             reset connection.
   Warning:Multiple clock statements appear in the reset loop.
并且不能继续综合下去,有熟悉行为综合的给看下,多谢!
GMT+8, 2025-12-26 13:04 , Processed in 0.375673 second(s), 6 queries , Gzip On, Redis On.
