查看: 4501|回复: 1
[求助] spectre无法生成SMIC 018中的电阻网表
发表于 2010-5-11 12:21:30 | 显示全部楼层 |阅读模式
请教老手们一个问题,我现在用smic工艺的rhrpo电阻,但是仿真时却发现spectre无法生成该电阻的网表,icfb窗口中提示:The switch view schematic of cell rhrpo in library smic18mmrf has no instances,hence is being ignored.To netlist this cell,add this view to the stop list and to ignore any particular instance use nlAction="ignore"
发表于 2011-6-20 12:54:23 | 显示全部楼层
后来这个问题好了吗?怎么解决的?
GMT+8, 2025-12-5 16:24 , Processed in 0.017924 second(s), 6 queries , Gzip On, Redis On.
