查看: 4187|回复: 7
[求助] dc启动有点问题。
发表于 2010-5-5 17:32:07 | 显示全部楼层 |阅读模式
# shell for .bashrc
##假设   scl安装在/usr/synopsys/scl.10.9.3下面
##      IC Compiler安装在/usr/synopsys/icc2005下面
##      TerraMax安装在/usr/synopsys/tetramax2007下面
##      license位于/usr/synopsys/license/synopsys.dat
export SYNOPSYS="/usr/synopsys/tetramax2007"
export SYNOPSYS="/usr/synopsys/Z-2007.03-SP5:"$SYNOPSYS
export SYNOPSYS_TMAX="/usr/synopsys/tetramax2007"
export PATH="/usr/synopsys/scl.10.9.3/linux/bin:"$PATH
export PATH="/usr/synopsys/tetramax2007/linux/syn/bin:/usr/synopsys/tetramax2007/bin:"$PATH
export PATH="/usr/synopsys/Z-2007.03-SP5/bin:"$PATH
export SNPSLMD_LICENSE_FILE=27000@wzc
export LM_LICENSE_FILE="/usr/synopsys/license/synopsys.dat"
alias ssss="sssverify /usr/synopsys/license/synopsys.dat"
alias lmli2="/usr/synopsys/scl.10.9.3/linux/bin/lmgrd -c /usr/synopsys/license/synopsys.dat -l ~/syn_lic.log"
alias lmst3="/usr/synopsys/scl.10.9.3/linux/bin/lmstat –c /usr/synopsys/license/synopsys.dat"
# for tetramax
alias tm="tmax32"
alias tmg="tmax -gui"
alias dc="dc_shell"
alias dv="design_vision"
可以启动dv不能启动dc,这个为什么呀
发表于 2010-5-6 08:23:06 | 显示全部楼层
dc不能启动的错误信息?贴来看看;
 楼主| 发表于 2010-5-7 13:24:12 | 显示全部楼层
2# hzhou
####  dc启动  ########################
wangzecheng@wzc:~$ dc
grep: /etc/redhat-release: 没有那个文件或目录
                        DC Professional (TM)
                           DC Expert (TM)
                            DC Ultra (TM)
                       FloorPlan Manager (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                        Library Compiler (TM)
                      DesignWare Developer (TM)
                          DFT Compiler (TM)
                            BSD Compiler
                         Power Compiler (TM)
           Version Z-2007.03-SP5 for linux -- Oct 16, 2007
              Copyright (c) 1988-2007 by Synopsys, Inc.
                         ALL RIGHTS RESERVED
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
The above trademark notice does not imply that you are licensed to use
all of the listed products. You are licensed to use only those products
for which you have lawfully obtained a valid license key.
Error: For optimal performance and to take advantage of the
latest enhancements and capabilities in Synopsys synthesis products,
we recommend the use of XG mode. XG mode is available in Tcl only.
DCSH mode will not be supported in future releases.
Information: If you want to use dc_shell in DCSH mode, please use
dc_shell -db_mode -dcsh_mode.
For more information, please go to http://solvnet.synopsys.com
##########   启动dc_shell-t  ####################
wangzecheng@wzc:~$ dc_shell-t
                           DC Expert (TM)
                            DC Ultra (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                          DFT Compiler (TM)
                            BSD Compiler
                         Power Compiler (TM)
                         ALL RIGHTS RESERVED
Initializing...
Starting shell in XG mode...
dc_shell-xg-t>
#####  dv启动   我用的是debian5.03   ##############
                           DC Expert (TM)
                            DC Ultra (TM)
                          HDL Compiler (TM)
                         VHDL Compiler (TM)
                          DFT Compiler (TM)
                            BSD Compiler
                         Power Compiler (TM)
                         ALL RIGHTS RESERVED
Initializing...
design_vision-xg-t> design_vision-xg-t>
#####  .bashrc 关于synopsys的    ###################
export SNPSLMD_LICENSE_FILE="/usr/synopsys/license/synopsys.dat"
# for tetramax
alias tm="tmax32"
alias dc="dc_shell"
发表于 2010-7-5 17:57:01 | 显示全部楼层
DDDDDDDDDDDDD
发表于 2010-7-31 01:41:03 | 显示全部楼层
gdfgdfg
发表于 2010-7-31 01:48:17 | 显示全部楼层
sdfgsdfgsdfg
发表于 2010-8-13 22:04:13 | 显示全部楼层
不知道啊
发表于 2019-12-12 12:48:32 | 显示全部楼层
请教下怎么把Library Compile集成在dc_shell里面呢
GMT+8, 2025-12-26 21:24 , Processed in 2.170272 second(s), 7 queries , Gzip On, Redis On.
