楼主: 风在吼
[资料] 一本关于混合信号设计的新书
发表于 2010-5-2 03:34:31 | 显示全部楼层
thank you~
发表于 2010-5-2 11:09:22 | 显示全部楼层
good job
 楼主| 发表于 2010-5-2 11:29:24 | 显示全部楼层
希望大家顶起来
发表于 2010-5-2 14:25:44 | 显示全部楼层
ddddddddddddddddd
发表于 2010-5-2 20:28:10 | 显示全部楼层
不错 真的很不错的资料
发表于 2010-5-2 21:33:17 | 显示全部楼层
1# 风在吼
看看
发表于 2010-5-2 21:35:59 | 显示全部楼层
1# 风在吼
file:///Users/wenxianguang/Downloads/Adaptive%20Techniques%20for%20Mixed%20Signal%20System%20on%20Chip.pdf
发表于 2010-5-3 09:09:20 | 显示全部楼层
下来看看...
发表于 2010-5-3 10:02:37 | 显示全部楼层
thanks
 楼主| 发表于 2010-5-3 10:59:36 | 显示全部楼层
Contents
1. Introduction 1
1.1
1.1.1
1.1.2
1.1.3
1.2
1.3
1.4
2.1
2.1.1
2.1.2
2.2
2.3
3.1
3.1.1
Categories of Variations in Analog and Mixed Signal ICs............... 2
The Essence of Adaptation............................................................... 5
The Process of Adaptation................................................................ 6
Book Outline.................................................................................... 8
2. Adaptive Architectures.......................................................................... 11
Automatic Tuning........................................................................... 12
Voltage, Current, and Time References........................ 16
Electronically Tunable Elements................................... 21
Post Fabrication Tuning.................................................................. 35
Summary......................................................................................... 36
3. Tunable Elements................................................................................... 39
Voltage-Controlled Transconductors.............................................. 39
A Triode-Based Voltage-Controlled Transconductor... 40
Dedication...................................................................................................... v
Preface........................................................................................................... xi
Circuit Level Variations.................................................. 2
Network Level Variations................................................ 5
System Level Variations................................................... 4
3.1.2
3.1.3
3.2
3.2.1
3.2.2
3.2.3
3.3
4.1
4.1.1
4.1.2
4.2
4.2.1
4.2.2
4.3
5.1
5.1.1
5.1.2
5.1.3
5.1.4
5.1.5
5.2
5.2.1
5.2.2
5.2.3
5.3
5.3.1
5.3.2
5.4
6.1
6.2
6.3
6.3.1
6.3.2
6.3.3
6.4
An Improved Voltage-Controlled Transconductor....... 45
Simulations Results...................................................... 48
Comparators.................................................................................... 55
Offset Comparators....................................................... 56
A Voltage-Controlled Offset Comparator.................... 58
Simulation Results........................................................ 63
Summary.........................................................................................  65
4. On-Chip Resistors and Capacitors....................................................... 67
Passive Resistors............................................................................. 68
Accuracy of Passive Resistors...................................... 72
Matching Properties of Passive Resistors..................... 77
Passive Capacitors........................................................................... 80
Accuracy of Passive Capacitors.................................... 90
Matching Properties of Passive Capacitors................... 92
Summary......................................................................................... 94
5. A Digital Adaptive Technique for On-Chip Resistors....................... 95
The Calibration Technique.............................................................. 97
Variation Range Quantization Concept........................ 97
The Resistor Block........................................................ 98
The Algorithm............................................................... 99
Quantifying the Drift................................................... 103
Tuning Signal Generation........................................... 104
Practical Advantages and Limitations........................................... 107
Accuracy Limitations.................................................. 107
Practical Advantages................................................... 109
Design Considerations................................................ 112
Applications.................................................................................. 113
A 1.65 Gbps Transceiver............................................. 117
6. Equalization.......................................................................................... 121
Intersymbol Interference............................................................... 121
Eye Diagrams................................................................................ 129
Equalization Architectures............................................................ 131
The Feed-Forward Architecture.................................. 133
The Feed-Back Architecture....................................... 136
The Mixed Feed-Forward Feed-back Architecture..... 139
Implementation Techniques.......................................................... 139
A 480 Mbps Transceiver............................................. 114
Summary....................................................................................... 118
6.5
7.1
7.2
7.3
7.3.1
7.3.2
7.3.3
7.3.4
7.3.5
7.3.6
7.4
7.5
7.6
Summary....................................................................................... 140
7. An Analog Adaptive Equalizer for Wire Line Transceivers............ 141
Motivation..................................................................................... 142
Transmission Channel Modeling................................................... 143
A Feed-Forward Adaptive Equalizer............................................ 146
The Forward Equalizer................................................ 148
The Slicer.................................................................... 150
The Reference Signal Generator................................. 153
The Band-Pass Filter................................................... 154
The Differential-Difference Squarer........................... 154
Simulation Results........................................................................ 159
Measurements Results................................................................... 167
Bibliography.............................................................................................. 173
Index.......................................................................................................... 177
Summary.......................................................................................170
The Integrator.............................................................. 156
GMT+8, 2025-11-22 18:05 , Processed in 0.020019 second(s), 2 queries , Gzip On, Redis On.
