查看: 11296|回复: 8
[求助] DC安装问题???
发表于 2010-4-24 22:15:23 | 显示全部楼层 |阅读模式
各位大虾, 我在centos上安装dc,感觉路径与licence都是好的,当我运行DC 但系统提示:Warning:  Site Information is not available ... Have you run install_site?
Fatal: Design Compiler is not enabled. (DCSH-1)
运行dv时:Warning:  Site Information is not available ... Have you run install_site?
Unable to obtain feature 'Design-Vision ' because:
Error: Cannot open key file '/usr/eda/synopsys/dc/admin/license/key' or a licensing environment parameter has not been set correctly. (SEC-2)
Unable to obtain feature 'Design-Analyzer ' because:
Fatal: At least one of the following must be enabled : Design-Vision, Design-Analyzer. (DCSH-10)
 楼主| 发表于 2010-4-24 22:16:34 | 显示全部楼层
希望各位大虾帮助解决一下, 谢谢!!!
发表于 2010-4-25 00:25:50 | 显示全部楼层
很明显是license问题,或者环境变量没设好
 楼主| 发表于 2010-4-25 17:23:21 | 显示全部楼层
谢谢!!!
发表于 2011-9-12 19:05:19 | 显示全部楼层
请参考:win7 ubuntu11.04双系统上成功安装synopsys DesignCompiler2008.09及相关软件
http://bbs.eetop.cn/thread-306934-1-1.html
发表于 2017-3-5 10:12:32 | 显示全部楼层
回复 1# chanon
   kanyikan    zhengyudaozhegewenti a
发表于 2019-6-28 19:23:06 | 显示全部楼层
想问下这个问题怎么解决的
发表于 2020-12-31 13:57:34 | 显示全部楼层
一样遇到了这个问题,感觉是license的问题,不知道怎么配置
发表于 2021-7-25 18:45:24 | 显示全部楼层
来学习一下
GMT+8, 2025-9-16 09:28 , Processed in 0.023593 second(s), 6 queries , Gzip On, Redis On.
