查看: 4723|回复: 19
[原创] 2009年最新master论文Wideband PLL System as a Clock Multiplier
发表于 2010-4-20 23:28:14 | 显示全部楼层 |阅读模式
In this study, the theory, design and analysis of PLL circuits are examined and a 4:9GHz   5:9GHz Wideband CMOS PLL Frequency Synthesizer is designed and implemented in IBM
65nm digital-process.
The objective of this thesis work is to understand the limitations in Wideband PLL systems
when the application frequency range extends to multiple gigahertz. This study explores the
inband noise contribution of PLL blocks and also investigates solutions to high frequency
operation of phase frequency detectors and charge pumps.
A high frequency phase-frequency detector topology is presented. With this topology, static
phase error of the loop remains close to zero even if the charge-pump has a large amount
of current mismatch. A design which is capable correct operation up to a frequency 1.74
GHz is designed. A high frequency di erential charge pump circuit with glitch suppression
is presented. The VCO of the PLL is implemented with a mutlipath loop ring oscillator.
The VCO has a better supply noise performance compared to conventional ring oscillators
but however it is still not suitable for applications with noisy supply, thus o chip supply
decoupling is used. VCO operates within 4:79GHz   6:54GHz for all process corners. The
frequency divider which is used from project library has a constant division ratio of 6.
Entire PLL design consumes 14.9 mW from 1.2 V supply, under typical conditions. Total
area of the PLL is 1 mm x 800 um including the pads.
Wideband PLL System as a Clock.part1.rar
3.81 MB, 下载次数: 102 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Wideband PLL System as a Clock.part2.rar
478.71 KB, 下载次数: 92 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-4-21 11:07:12 | 显示全部楼层
TUDelft
发表于 2010-4-21 11:16:56 | 显示全部楼层
看看应该不错吧,谢谢了!!!!
发表于 2010-4-21 11:18:56 | 显示全部楼层
不知道有么有频率更高一点的pll呢,急需啊!
发表于 2010-5-19 03:34:10 | 显示全部楼层
感謝大大的分享, 應該很受用
发表于 2010-7-19 00:39:16 | 显示全部楼层
Thanks
发表于 2010-7-19 00:40:44 | 显示全部楼层
謝謝!謝謝
发表于 2010-7-23 15:00:30 | 显示全部楼层
thx for sharing
发表于 2010-7-23 16:57:17 | 显示全部楼层
ddddddddddddd
发表于 2010-7-23 16:58:20 | 显示全部楼层
ddddddddddddddd
GMT+8, 2025-12-29 01:46 , Processed in 0.025904 second(s), 7 queries , Gzip On, Redis On.
