查看: 3071|回复: 5
[原创] fractional charge pump(1.5x) and regulated chareg pump
发表于 2010-4-15 09:22:33 | 显示全部楼层 |阅读模式
Hi guys,
Regarding 1.5x chareg pump,
I'm new tocharge pump,previously I though charge pump can only achieve 2^n of the input voltage,not sure about how to realize the fractional times ,is it realized by the synthesis of the capacitors using different voltage?
Regarding regulatd charge pump,
Can the output voltage be regulated,is it similar with the buck and boost,what's the principal behind this?
Thanks
发表于 2010-4-15 16:39:17 | 显示全部楼层
你可以去看看ADI,maixim,TI的产品,它们的网站上都有的。
1.5X的要多用一个电容。
发表于 2010-4-17 09:54:41 | 显示全部楼层
charge pump和buck/boost有本质上的不同,能量效率是不可比的。只不过charge pump不需要电感,便宜
发表于 2010-4-17 16:24:50 | 显示全部楼层
[code][/code]
 楼主| 发表于 2010-4-18 15:11:45 | 显示全部楼层
非常感谢~~
发表于 2011-4-1 04:47:38 | 显示全部楼层
thank you for the knowledge
GMT+8, 2025-12-12 09:08 , Processed in 0.016525 second(s), 6 queries , Gzip On, Redis On.
