查看: 3029|回复: 0
[求助] 求synplify综合报告某警告的含义
发表于 2010-4-11 09:43:09 | 显示全部楼层 |阅读模式
用synplify综合时产生了如下警告: @W: FX474 |User specified initial value found in some of the sequential elements in the design. Applying an initial value to a register may not deliver the best synthesis results. For example, registers with initial values may be preserved and retiming/pipelining may not be performed. To improve synthesis results you may want to remove the register initialization from the RTL code
          没太看明白,请高手指点下:User specified initial value found in some of the sequential elements in the design是个什么情况?可否举个例说明一下?谢谢
GMT+8, 2025-12-25 15:33 , Processed in 0.023579 second(s), 4 queries , Gzip On, Redis On.
