查看: 2775|回复: 3
[原创] DC安装的问题--求解!!!
发表于 2010-4-4 18:42:43 | 显示全部楼层 |阅读模式
安装完软件,加载license时报错
[root@myhost bin]# ./lmgrd -c /usr/synopsys/license/lic_synopsys.dat
18:33:58 (lmgrd) -----------------------------------------------
18:33:58 (lmgrd)   Please Note:
18:33:58 (lmgrd)
18:33:58 (lmgrd)   This log is intended for debug purposes only.
18:33:58 (lmgrd)   In order to capture accurate license
18:33:58 (lmgrd)   usage data into an organized repository,
18:33:58 (lmgrd)   please enable report logging. Use Macrovision's
18:33:58 (lmgrd)   software license administration  solution,
18:33:58 (lmgrd)   FLEXnet Manager, to  readily gain visibility
18:33:58 (lmgrd)   into license usage data and to create
18:33:58 (lmgrd)   insightful reports on critical information like
18:33:58 (lmgrd)   license availability and usage. FLEXnet Manager
18:33:58 (lmgrd)   can be fully automated to run these reports on
18:33:58 (lmgrd)   schedule and can be used to track license
18:33:58 (lmgrd)   servers and usage across a heterogeneous
18:33:58 (lmgrd)   network of servers including Windows NT, Linux
18:33:58 (lmgrd)   and UNIX. Contact Macrovision at
18:33:58 (lmgrd)   www.macrovision.com for more details on how to
18:33:58 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
18:33:58 (lmgrd)   for your enterprise.
18:33:58 (lmgrd)
18:33:58 (lmgrd)
18:33:58 (lmgrd)
18:33:58 (lmgrd) The license server manager (lmgrd) running as root:
18:33:58 (lmgrd)        This is a potential security problem
18:33:58 (lmgrd)        and is not recommended.
[root@myhost bin]# 18:33:58 (lmgrd) FLEXnet Licensing (v10.8.5.0 build 31891 i86_re3) started on myhost (linux) (4/4/2010)
18:33:58 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
18:33:58 (lmgrd) US Patents 5,390,297 and 5,671,412.
18:33:58 (lmgrd) World Wide Web:  http://www.macrovision.com
18:33:58 (lmgrd) License file(s): /usr/synopsys/license/lic_synopsys.dat
18:33:58 (lmgrd) lmgrd tcp-port 27000
18:33:58 (lmgrd) Starting vendor daemons ...
18:33:58 (lmgrd) license daemon: execute process failed: (.//usr/synop) -T myhost 10.8 3 -c /usr/synopsys/license/lic_synopsys.dat
18:33:58 (lmgrd) license daemon: system error code: No such file or directory
18:33:58 (lmgrd) Started /usr/synop (internet tcp_port 38977 pid 3691)
求各位大虾帮助阿
发表于 2010-4-5 09:53:47 | 显示全部楼层
是不是这个.dat文件的路径不对
发表于 2011-9-2 20:56:07 | 显示全部楼层
同问这个问题,+1
发表于 2011-9-4 22:48:34 | 显示全部楼层
下面显示这么清楚,还问,都不看E文的吗
GMT+8, 2025-12-23 10:38 , Processed in 0.016505 second(s), 5 queries , Gzip On, Redis On.
