查看: 3985|回复: 1
[求助] FPGA/CPLD控制flash的读写?
发表于 2010-3-24 09:12:36 | 显示全部楼层 |阅读模式
最近看flash的datasheet,不明白他的program和write命令有何区别。用过的大侠能否给说一下。
多谢多谢!
发表于 2010-3-24 12:53:53 | 显示全部楼层
Program Suspend/Program Resume Command Sequence
The Program Suspend command allows the system to interrupt a programming operation or a Write to Buffer
programming operation so that data can be read from any non-suspended sector. When the Program
Suspend command is written during a programming process, the device halts the program operation within
15 μs maximum (5μs typical) and updates the status bits. Addresses are not required when writing the
Program Suspend command.
GMT+8, 2025-12-26 21:11 , Processed in 0.016436 second(s), 6 queries , Gzip On, Redis On.
