查看: 19885|回复: 58
[资料] 发几本验证方面的经典书籍
发表于 2010-3-14 14:21:32 | 显示全部楼层 |阅读模式
SystemVerilog for Verification, 2nd Ed.pdf
1. VERIFICATION GUIDELINES 1
1.1 The Verification Process 2
1.2 The Verification Methodology Manual 4
1.3 Basic Testbench Functionality 5
1.4 Directed Testing 5
1.5 Methodology Basics 7
1.6 Constrained-Random Stimulus 8
1.7 What Should You Randomize? 10
1.8 Functional Coverage 13
1.9 Testbench Components 14
1.10 Layered Testbench 15
1.11 Building a Layered Testbench 21
1.12 Simulation Environment Phases 22
1.13 Maximum Code Reuse 23
1.14 Testbench Performance 23
1.15 Conclusion 24
2. DATA TYPES 25
2.1 Built-In Data Types 25
2.2 Fixed-Size Arrays 28
2.3 Dynamic Arrays 34
2.4 Queues 36
2.5 Associative Arrays 38
viii Contents
2.6 Linked Lists 40
2.7 Array Methods 41
2.8 Choosing a Storage Type 46
2.9 Creating New Types with typedef 48
2.10 Creating User-Defined Structures 50
2.11 Type conversion 52
2.12 Enumerated Types 55
2.13 Constants 59
2.14 Strings 59
2.15 Expression Width 60
2.16 Conclusion 61
3. PROCEDURAL STATEMENTS
AND ROUTINES 63
3.1 Procedural Statements 63
3.2 Tasks, Functions, and Void Functions 65
3.3 Task and Function Overview 65
3.4 Routine Arguments 66
3.5 Returning from a Routine 72
3.6 Local Data Storage 73
3.7 Time Values 75
3.8 Conclusion 77
4. CONNECTING THE TESTBENCH
AND DESIGN 79
4.1 Separating the Testbench and Design 80
4.2 The Interface Construct 82
4.3 Stimulus Timing 88
4.4 Interface Driving and Sampling 96
4.5 Connecting It All Together 103
4.6 Top-Level Scope 104
4.7 Program – Module Interactions 106
4.8 SystemVerilog Assertions 107
4.9 The Four-Port ATM Router 109
4.10 The ref Port Direction 117
4.11 The End of Simulation 118
4.12 Directed Test for the LC3 Fetch Block 118
4.13 Conclusion 124
5. BASIC OOP 125
5.1 Introduction 125
5.2 Think of Nouns, not Verbs 126
5.3 Your First Class 126
Contents ix
5.4 Where to Define a Class 127
5.5 OOP Terminology 128
5.6 Creating New Objects 129
5.7 Object Deallocation 132
5.8 Using Objects 134
5.9 Static Variables vs. Global Variables 134
5.10 Class Methods 138
5.11 Defining Methods Outside of the Class 139
5.12 Scoping Rules 141
5.13 Using One Class Inside Another 144
5.14 Understanding Dynamic Objects 147
5.15 Copying Objects 151
5.16 Public vs. Local 157
5.17 Straying Off Course 157
5.18 Building a Testbench 158
5.19 Conclusion 159
6. RANDOMIZATION 161
6.1 Introduction 161
6.2 What to Randomize 162
6.3 Randomization in SystemVerilog 165
6.4 Constraint Details 167
6.5 Solution Probabilities 178
6.6 Controlling Multiple Constraint Blocks 182
6.7 Valid Constraints 183
6.8 In-line Constraints 184
6.9 The pre_randomize and post_randomize Functions 185
6.10 Random Number Functions 187
6.11 Constraints Tips and Techniques 187
6.12 Common Randomization Problems 193
6.13 Iterative and Array Constraints 195
6.14 Atomic Stimulus Generation vs. Scenario Generation 204
6.15 Random Control 207
6.16 Random Number Generators 209
6.17 Random Device Configuration 213
6.18 Conclusion 216
7. THREADS AND INTERPROCESS COMMUNICATION 217
7.1 Working with Threads 218
7.2 Disabling Threads 228
7.3 Interprocess Communication 232
7.4 Events 233
7.5 Semaphores 238
7.6 Mailboxes 240
x Contents
7.7 Building a Testbench with Threads and IPC 253
7.8 Conclusion 257
8. ADVANCED OOP AND TESTBENCH GUIDELINES 259
8.1 Introduction to Inheritance 260
8.2 Blueprint Pattern 265
8.3 Downcasting and Virtual Methods 270
8.4 Composition, Inheritance, and Alternatives 274
8.5 Copying an Object 279
8.6 Abstract Classes and Pure Virtual Methods 282
8.7 Callbacks 284
8.8 Parameterized Classes 290
8.9 Conclusion 293
9. FUNCTIONAL COVERAGE 295
9.1 Coverage Types 298
9.2 Functional Coverage Strategies 301
9.3 Simple Functional Coverage Example 303
9.4 Anatomy of a Cover Group 305
9.5 Triggering a Cover Group 307
9.6 Data Sampling 310
9.7 Cross Coverage 319
9.8 Generic Cover Groups 325
9.9 Coverage Options 327
9.10 Analyzing Coverage Data 329
9.11 Measuring Coverage Statistics During Simulation 331
9.12 Conclusion 332
10. ADVANCED INTERFACES 333
10.1 Virtual Interfaces with the ATM Router 334
10.2 Connecting to Multiple Design Configurations 342
10.3 Procedural Code in an Interface 347
10.4 Conclusion 350
11. A COMPLETE SYSTEMVERILOG
TESTBENCH 351
11.1 Design Blocks 351
11.2 Testbench Blocks 356
11.3 Alternate Tests 377
11.4 Conclusion 379
12. INTERFACING WITH C 381
12.1 Passing Simple Values 382
Contents xi
12.2 Connecting to a Simple C Routine 385
12.3 Connecting to C++ 393
12.4 Simple Array Sharing 398
12.5 Open arrays 400
12.6 Sharing Composite Types 404
12.7 Pure and Context Imported Methods 407
12.8 Communicating from C to SystemVerilog 407
12.9 Connecting Other Languages 418
12.10 Conclusion 419
References 421
Index 423
2.47 MB, 下载次数: 877 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-3-14 14:24:59 | 显示全部楼层
1# chocobocn
Springer - SystemVerilog for Verification.pdf
1.41 MB, 下载次数: 213 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-3-14 14:33:04 | 显示全部楼层
2# chocobocn
0387255389 - Verification Methodology Manual for SystemVerilog.pdf
4.22 MB, 下载次数: 243 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2010-3-14 19:47:03 | 显示全部楼层
不错!
发表于 2010-3-14 21:28:16 | 显示全部楼层
这好需要,谢谢楼主了
发表于 2010-3-14 21:56:06 | 显示全部楼层
好东西!
发表于 2010-3-22 11:22:43 | 显示全部楼层
多谢多谢
发表于 2010-3-25 19:37:39 | 显示全部楼层
谢谢楼主的大方分享!!!!
发表于 2010-3-25 23:39:20 | 显示全部楼层
这好需要,谢谢楼主了
发表于 2010-3-26 14:08:34 | 显示全部楼层
多谢了!
GMT+8, 2025-12-23 00:30 , Processed in 0.026103 second(s), 6 queries , Gzip On, Redis On.
