查看: 4011|回复: 3
[资料] MST理论的论文
发表于 2010-3-6 23:56:10 | 显示全部楼层 |阅读模式
有关MST的论文,推荐给大家。
2楼是这篇paper的摘要
Considerations for Fast Settling Operational.PDF
853.79 KB, 下载次数: 26 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2010-3-6 23:58:58 | 显示全部楼层
Abstracr-The design considerations for fast-settling operational ampli-
fiers(opamps)are significantly different between sampled-data switched-
capacitor(SC)and conventional continuous-time applications.In SC cir-
cuits,the shape of the output voltage waveform of an opamp is of no
consequence provided that the output settles to within a specified tolerance
of its steady-state value prior to the next sampling instant.This feature
allows for an optimum opamp frequency shaping to obtain a minimum
small-signal settling time.The theory applies to any opamp that is well
approximated by a two-pole model,including the conventional two-stage
and single-stage folded-cascode topologies.As the commonly-used equiva-
lent-circuit Miller-effect model for frequency compensation has generally
been improperly applied to two-stage transconductance amplifiers,it does
not provide sufficient accuracy to achieve the optimum phase margin
condition.Therefore,the use of equivalent-circuit models has been refined
to provide greater accuracy and to eliminate some previous misconcep-
tions.
摘要贴出来。
发表于 2010-3-7 17:37:05 | 显示全部楼层
thanks for sharing
发表于 2013-3-22 10:38:03 | 显示全部楼层
GMT+8, 2025-12-29 08:49 , Processed in 0.022322 second(s), 9 queries , Gzip On, Redis On.
