查看: 3648|回复: 1
[求助] ARM与FPGA之间的数据传输(出现问题,请高手帮忙,附源程序)
发表于 2010-2-24 13:33:45 | 显示全部楼层 |阅读模式
ARM与FPGA之间的数据传输:
ARM(主)负责分析处理数据,FPGA(从)负责收集存储数据,两者之间通过地址/数据总线方式通信(不复用),下面是我编写的通信程序。ARM通过FPGA的内部RAM对数据进行读写处理。开发软件libero,在仿真中数据读写都正确,写到板子上功能就不对了,大家给分析下我写的程序是否有问题,谢谢!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
----FPGA内部寄存器地址定义:
package  interface is
constant addr_reg1 : std_logic_vector(9 downto 0) := "0000000000";
constant addr_reg2 : std_logic_vector(9 downto 0) := "0000000001";
constant addr_reg3 : std_logic_vector(9 downto 0) := "0000000010";
constant addr_reg4 : std_logic_vector(9 downto 0) := "0000000011";
end;
library ieee;
use work.interface.all;
entity arm_fpga is
port(
mcudata : inout std_logic_vector(7 downto 0);--8位数据
mcuaddress : in std_logic_vector(9 downto 0);--10位地址
wr : in std_logic;--写信号
rd : in std_logic;
cs : in std_logic;
led : out std_logic_vector(7 downto 0));
end;
architecture  armfpga of arm_fpga is
signal  addresstemp : std_logic_vector(9 downto 0);--内部寄存器
signal  datatemp1, datatemp2, datatemp3, datatemp4 : std_logic_vector(7 downto 0);
signal  wr_en,rd_en : std_logic;--读写使能
begin
addresstemp <= mcuaddress;
wr_en <= (wr and rd) or wr;
rd_en <= (wr and rd) or rd;
--ARM写数据到FPGA:
process(wr,wr_en)
begin
if  wr'event and wr = '0' then
if cs = '0'and  wr_en = '0' then
case addresstemp is
when addr_reg1 =>
datatemp1 <= mcudata;
when addr_reg2 =>
datatemp2 <= mcudata;
when addr_reg3 =>
datatemp3 <= mcudata;
when addr_reg4 =>
datatemp4 <= mcudata;
when others => null;
end case;
end if;
end if;
end process;
--ARM从FPGA读取数据:
process(rd,rd_en)
begin
if  rd'event and rd = '0'  then
if cs = '0' and rd_en = '0' then
case addresstemp is
when addr_reg1 =>
mcudata <= datatemp1;
when addr_reg2 =>
mcudata <= datatemp2;
when addr_reg3 =>
mcudata <= datatemp3;
when addr_reg4 =>
mcudata <= datatemp4;
end case;
end if;
end if;
end process;
led <= mcudata; --验证传输数据,LED显示
end;
还有一个问题,我在综合的时候出现了一个警告:
Failed to find top level module 'work.arm_fpga' as specified in project file
这是什么原因?没搞明白
发表于 2010-4-18 12:09:53 | 显示全部楼层
FPGA与ARM之间数据采用共享存储器方式进行时,要注意对来自ARM得信号进行必要的防抖,另外你可以直接将来自ARM对存储器的操作信号直接接到FPGA内部的RAM接口,这样就可以了!
GMT+8, 2025-12-29 07:59 , Processed in 0.532825 second(s), 6 queries , Gzip On, Redis On.
