查看: 3144|回复: 8
[转贴] 锁相环仿真程序
发表于 2010-2-22 17:56:20 | 显示全部楼层 |阅读模式
频偏:-60Hz
相偏:在0--2*pi内随机分布
程序及结果如下:
clear all;
close all;
%定义锁相环的工作模式:单载波为“1”、BPSK调制为“2”、QPSK调制为“3”
PLL_Mode = 1;
%仿真数据长度
Simulation_Length=1000;
%基带信号
if PLL_Mode == 1
    I_Data=ones(Simulation_Length,1);
    Q_Data=I_Data;
else if PLL_Mode == 2
        I_Data=randint(Simulation_Length,1)*2-1;
        Q_Data=zeros(Simulation_Length,1);
    else
        Q_Data=randint(Simulation_Length,1)*2-1;
    end
end
Signal_Source=I_Data + j*Q_Data;
%载波信号
Freq_Sample=2400;%采样率,Hz
Delta_Freq=-60;   %频偏,Hz
Time_Sample=1/Freq_Sample;
Delta_Phase=rand(1)*2*pi; %随机初相,Rad
Carrier=exp(j*(Delta_Freq/Freq_Sample*(1:Simulation_Length)+Delta_Phase));
%调制处理
Signal_Channel=Signal_Source.*Carrier';
%以下为锁相环处理过程
%参数清零
Signal_PLL=zeros(Simulation_Length,1);
NCO_Phase = zeros(Simulation_Length,1);
Discriminator_Out=zeros(Simulation_Length,1);
Freq_Control=zeros(Simulation_Length,1);
PLL_Phase_Part=zeros(Simulation_Length,1);
PLL_Freq_Part=zeros(Simulation_Length,1);
%环路处理
C1=0.022013;
C2=0.00024722;
for i=2:Simulation_Length
    Signal_PLL(i)=Signal_Channel(i)*exp(-j*mod(NCO_Phase(i-1),2*pi));
    I_PLL(i)=real(Signal_PLL(i));
    Q_PLL(i)=imag(Signal_PLL(i));
    if PLL_Mode == 1
        Discriminator_Out(i)=atan2(Q_PLL(i),I_PLL(i));
            Discriminator_Out(i)=sign(I_PLL(i))*Q_PLL(i)/abs(Signal_PLL(i));
        else
            Discriminator_Out(i)=(sign(I_PLL(i))*Q_PLL(i)-sign(Q_PLL(i))*I_PLL(i))...
                      /(sqrt(2)*abs(Signal_PLL(i)));
        end
    end
    PLL_Phase_Part(i)=Discriminator_Out(i)*C1;
    Freq_Control(i)=PLL_Phase_Part(i)+PLL_Freq_Part(i-1);
    PLL_Freq_Part(i)=Discriminator_Out(i)*C2+PLL_Freq_Part(i-1);
    NCO_Phase(i)=NCO_Phase(i-1)+Freq_Control(i);
end
%画图显示结果
figure
subplot(2,2,1)
plot(-PLL_Freq_Part(2:Simulation_Length)*Freq_Sample);
grid on;
title('锁相环频率响应曲线');
axis([1 Simulation_Length -100 100]);
subplot(2,2,2)
plot(PLL_Phase_Part(2:Simulation_Length)*180/pi);
title('锁相环相位响应曲线');
axis([1 Simulation_Length -2 2]);
grid on;
%设定显示范围
Show_D=300; %起始位置
Show_U=900; %终止位置
Show_Length=Show_U-Show_D;
subplot(2,2,3)
plot(Signal_Channel(Show_D:Show_U),'*');
title('进入锁相环的数据星座图');
axis([-2 2 -2 2]);
grid on;
hold on;
subplot(2,2,3)
plot(Signal_PLL(Show_D:Show_U),'r*');
grid on;
subplot(2,2,4)
title('锁相环锁定及稳定后的数据星座图');
axis([-2 2 -2 2]);
grid on;
figure
%设定显示范围
Show_D=300; %起始位置
Show_U=350; %终止位置
subplot(2,2,1)
plot(I_Data(Show_D:Show_U));
grid on;
title('I路信息数据');
axis([1 Show_Length -2 2]);
subplot(2,2,2)
plot(Q_Data(Show_D:Show_U));
grid on;
title('Q路信息数据');
subplot(2,2,3)
plot(I_PLL(Show_D:Show_U));
grid on;
title('锁相环输出I路信息数据');
subplot(2,2,4)
plot(Q_PLL(Show_D:Show_U));
grid on;
title('锁相环输出Q路信息数据');
发表于 2010-2-24 20:58:17 | 显示全部楼层
~~~thanks~~~
发表于 2010-3-9 15:40:24 | 显示全部楼层
好的很,谢谢了!
发表于 2010-3-26 16:24:16 | 显示全部楼层
谢谢楼主!!!
发表于 2010-3-26 23:44:02 | 显示全部楼层
谢谢楼主!!
发表于 2010-3-27 08:46:03 | 显示全部楼层
雖然看不懂,但還是謝謝提供
发表于 2010-11-26 10:41:24 | 显示全部楼层
谢谢LZ,学习咯
发表于 2011-1-31 02:09:48 | 显示全部楼层
好的很,谢谢了!
发表于 2011-2-14 10:22:14 | 显示全部楼层
謝謝分享!!!!!
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 07:21 , Processed in 0.021738 second(s), 7 queries , Gzip On, Redis On.
