查看: 3339|回复: 4
多输出counter在xilinx中的综合,报错!为什么?
发表于 2004-12-14 14:04:34 | 显示全部楼层 |阅读模式
module CNT3 (RST,EN,CLK,OUT,OUT_EN,OUT_RES);
inputEN,RST,CLK;
outputOUT_EN,OUT_RES;
output[7:0]OUT;
reg[7:0]OUT;
regOUT_EN,OUT_RES;
always@(posedge CLK or posedge EN) begin
if(RST) begin
OUT<=0;
OUT_EN<=0;
OUT_RES<=0;
end
else if (EN)
    //fork
     begin
if (OUT ==8'b001100100)begin//Na=100
    OUT<=0;OUT_EN<=0;
    end
else
    OUT<=OUT+1;
  end
if (OUT==1)
OUT_EN<=1;
if (OUT==0)
OUT_RES<=1;
else
OUT_RES<=0;
    //join
end
endmodule
error:
ERROR:Xst:899 - N.v line 879: The logic for <OUT> does not match a known FF or Latch template.
ERROR:Xst:899 - N.v line 893: The logic for <OUT_EN> does not match a known FF or Latch template.
ERROR:Xst:899 - N.v line 896: The logic for <OUT_RES> does not match a known FF or Latch template.
Found 3 error(s). Aborting synthesis.
发表于 2004-12-14 16:28:34 | 显示全部楼层
把en从敏感表里面去掉。
发表于 2004-12-14 17:29:44 | 显示全部楼层
把敏感表里的EN改成RST,估计你本来就是这个意思,结果写错啦
 楼主| 发表于 2004-12-14 18:47:01 | 显示全部楼层
sqsq
 楼主| 发表于 2004-12-14 18:53:45 | 显示全部楼层
xilinx不支持 fork ...jion 用什么方法取代呢?前提是能同步工作。
GMT+8, 2025-10-11 11:38 , Processed in 0.016223 second(s), 4 queries , Gzip On, Redis On.
