楼主: bondultimate
Help for installing ASSURA 317 OA with IC610
发表于 2011-12-2 15:07:46 | 显示全部楼层
Usefully.
发表于 2012-10-11 15:00:52 | 显示全部楼层
Assura can be invoke in Layout window ?
发表于 2012-10-11 15:06:52 | 显示全部楼层
I installed assura4.1 but not supported to IC610...why??
发表于 2012-11-30 10:40:26 | 显示全部楼层
Hi newsunny ans fish200
how about the fish200's issues at #30?
发表于 2013-7-12 19:07:38 | 显示全部楼层
I installed Cadence IC610 in Ubuntu . When I type icfb& then virtuoso
window opens up but I cannot find any library cell.
When I open Library manager I get the following in the message box of
library manager:
Warning: ddUpdateLibList: Did not find any 'cds.lib' or lib.defs file.
In the terminal I get the following message:
[1] 3974
me@ubuntu:~/Cadence/IC610$ /home/me/Cadence/IC610/tools/dfII/bin/icfb:
97: cds_plat: not found
/home/me/Cadence/IC610/share/oa/bin/sysname: 328: /bin/awk: not found
In Virtuoso 6.1.0 window CDS.log I get the following message:
/home/me/Cadence/IC610/tools.lnx86/dfII/bin/libSelect: 32: cds_plat: not found
/home/me/Cadence/IC610/tools.lnx86/dfII/bin/libManager: 34: cds_plat: not found
My Queries are as follows:
2. How can I install cds.lib? Where can I find it?
3. I have downloaded the gpdk090_AnalogIC.tar How can I install gpdk
library? Please explain in detail since I am a novice.
4. How can I install ncsu library
发表于 2013-7-12 19:10:12 | 显示全部楼层
library manager:
[1] 3974
发表于 2013-7-16 09:17:08 | 显示全部楼层
[quote][/quote]
[root@localhost vanduongbk]# assura
/bin/ls: error while loading shared libraries: librt.so.1: cannot open shared object file: No such file or directory
/bin/sh: error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory
assura:   ERROR: No proper OA2.2 installation found. Fix the errors reported by cdsGetOABinPath.
assura:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
assura:          See the "OpenAccess Installation and Configuration Guide" before
assura:          you complete the configuration step. This manual is included with
assura:          the Cadence product documentation.
I have the same problem ,how to solve it .help me
发表于 2013-7-16 16:20:02 | 显示全部楼层
回复 3# bondultimate
I have install the ASSURA317 with IC610  but when I run lvs ,there exist error as follows:
Error:failedto initialize OpenAccess because:
Requested minor API version '34' is newerthan the minor API version '33' of the shared library
could you help me bondultimate~~~
发表于 2013-7-28 12:49:35 | 显示全部楼层
thanks dear thanksssssssssss
发表于 2014-3-9 09:32:44 | 显示全部楼层
回复 3# bondultimate
   ding ding
GMT+8, 2025-9-13 04:27 , Processed in 0.025404 second(s), 5 queries , Gzip On, Redis On.
