查看: 4665|回复: 9
[原创] VGA(DVI interface) Controller的高层次综合
发表于 2010-1-25 13:33:19 | 显示全部楼层 |阅读模式
// Genarate synch signal to drive DVI output, here 720P is as default
void vga_ctrl(volatile int24 *velXY, volatile uint8 *frameY, struct dvi_video *dvi_o, volatile uint1 *sync_enable)
    uint12 hcount = 0;
    uint11 vcount = 0;
    uint1 vga_data_rdenab = 0;
    uint1 sync_en = 0;
    uint1 video_active;
    struct dvi_video tmp_dvi_o;
    sync_en = *sync_enable;
  loop_while: while(sync_en)
        if (vcount < FRAME_HEIGHT)
            video_active = 1;
        else
            video_active = 0;
        if (video_active && (hcount >= (HSYNC_WIDTH + H_BACK_PORCH)) &&
            (hcount < (HSYNC_WIDTH + H_BACK_PORCH + LINE_WIDTH)))
            vga_data_rdenab = 1;
        else
        if (vga_data_rdenab)
            int24 tmp_velXY = *velXY;
            uint8 Yij = *frameY;
            int12 tmpX,tmpY;
            tmpX = (int12)(tmp_velXY>>12);
            tmpY = (int12)tmp_velXY;
            tmp_dvi_o.de = 1;
            tmp_dvi_o.vsync = SYNC_POLARITY_N;
            tmp_dvi_o.hsync = SYNC_POLARITY_N;
            int32 c = (Yij - 16) * 298;
            tmp_dvi_o.red   = (uint8)clip(((c + (tmpY>>1)*409 + 128) >> 8),0,255);
            tmp_dvi_o.green = (uint8)clip(((c - (tmpX*50) - (tmpY*104) + 128) >> 8),0,255);
            tmp_dvi_o.blue  = (uint8)clip(((c + (tmpX*258) + 128) >> 8),0,255);
        else
            tmp_dvi_o.de = 0;
            tmp_dvi_o.red = 0;
            tmp_dvi_o.green = 0;
            tmp_dvi_o.blue = 0;
            tmp_dvi_o.hsync = (hcount < HSYNC_WIDTH) ? SYNC_POLARITY : SYNC_POLARITY_N;
            if(vcount >= V_FRONT_PORCH + FRAME_HEIGHT && vcount < V_FRONT_PORCH + VSYNC_WIDTH + FRAME_HEIGHT)
                tmp_dvi_o.vsync = SYNC_POLARITY;
            else
        *dvi_o = tmp_dvi_o;
        if (hcount == (H_FRONT_PORCH + HSYNC_WIDTH + H_BACK_PORCH + LINE_WIDTH - 1))
            hcount = 0;
            if (vcount == (V_FRONT_PORCH + VSYNC_WIDTH + V_BACK_PORCH + FRAME_HEIGHT - 1))
                vcount = 0;
            else
                vcount = vcount + 1;
        else
            hcount = hcount + 1;
这是一个用C实现的VGA控制器的接口模块,其中头文件和上下文没有在这里提供(velXY),是一个视频处理design的一部分,在Xilinx VSK FPGA (spartan3adsp)上进行过原型验证。
高层次综合的约束是对while循环进行pipeline。
一般来说,高层次综合的特长是对数据处理为主的模块进行综合,但是随着工具越来越成熟,这些工具对控制为主的模块进行综合也没有任何问题了。
本文采用的工具:AutoESL公司的AutoPilot
发表于 2010-1-25 13:35:46 | 显示全部楼层
learning by learning
发表于 2010-7-27 06:38:06 | 显示全部楼层
sooooooo ! bom demais
发表于 2010-7-27 06:43:35 | 显示全部楼层
soooooooooo
发表于 2010-7-27 18:22:14 | 显示全部楼层
ESL的GateCount目前都還是太大
发表于 2010-8-6 13:27:35 | 显示全部楼层
good !!!!!!!!!!!!!!!!11
发表于 2010-10-28 18:55:47 | 显示全部楼层
谢谢...
发表于 2010-12-6 09:29:22 | 显示全部楼层
very good!
发表于 2010-12-10 01:00:33 | 显示全部楼层
nnnnnnnnnnnnnnnnnnnnnnnnnn
发表于 2010-12-14 10:08:36 | 显示全部楼层
这个要研究一下
GMT+8, 2025-12-17 18:34 , Processed in 0.023773 second(s), 7 queries , Gzip On, Redis On.
