查看: 8253|回复: 7
[求助] Sentaurus 软件安装问题
发表于 2010-1-15 15:36:17 | 显示全部楼层 |阅读模式
按照论坛上的安装方法安装之后,出现了以下问题
键入lmgrd后,出现
16:34:57 (snpslmd) Server started on localhost.localdomain for: SSS
16:34:57 (snpslmd)
16:34:57 (snpslmd) Licenses are case sensitive for TE_CATS
16:34:57 (snpslmd)
16:34:57 (lmgrd) snpslmd using TCP-port 55424
16:34:57 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
16:34:57 (snpslmd) ------------------------------------------------------------------
16:34:57 (snpslmd) Checking the integrity of the license file....
16:34:57 (snpslmd) Valid SSS feature found.
16:34:57 (snpslmd) The feature is needed to enable the other keys in your license file.
lisence程序应该是起来了吧?
[root@localhost ~]# GENESISe
***                         Sentaurus Workbench                          ***
***                          Version A-2008.09                           ***
***                        (1.4, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2009                        ***
***                            Synopsys, Inc.                            ***
***  This software and the associated documentation are confidential     ***
***  and proprietary to Synopsys, Inc.  Your use or disclosure of this   ***
***  software is subject to the terms and conditions of a written        ***
***  license agreement between you, or your company, and Synopsys, Inc.  ***
16:35:01 (snpslmd) TCP_NODELAY NOT enabled
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (BD4C30CE542428ED00A4) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
16:35:01 (snpslmd) UNSUPPORTED: "SK_swb_all" (PORT_AT_HOST_PLUS   ) root@localhost.localdomain  (License server system does not support this feature. (-18,327))
License checkout failed: License server system does not support this feature.
Feature:       swb_all
License path:  27000@localhost.localdomain
FLEXnet Licensing error:-18,147
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
        * feature is "swb_all"
        * version is "2008.09"
        * server name is "localhost.localdomain"
        * daemon is "snpslmd"
        * code is "BD4C30CE542428ED00A4"
        * expiry date is "31-dec-2019"
        * STROOT is "/usr/synopsys"
        * hostname is "localhost.localdomain"
        * display is "/dev/pts/1"
        * user is "root"
[root@localhost ~]#
为什么总提示那个swb不对
那位高人帮我看看 到底出了什么问题?
发表于 2011-1-3 11:06:44 | 显示全部楼层
回复 1# liuch23
    这个我也不太懂,高手请进
发表于 2011-1-3 13:54:03 | 显示全部楼层
我剛剛在別的地方回復了一樣的情況唷
可以參考一下,希望可以解決^^
http://bbs.eetop.cn/viewthread.php?tid=273900&pid=5675222&page=1&extra=#pid5675222
发表于 2011-3-3 09:19:07 | 显示全部楼层
和我安装出现的问题一摸一样,到现在还没解决
发表于 2011-4-28 12:17:00 | 显示全部楼层
认证通过,不过开始日期被显示在将来,大家见过没有呀?如何解决
***                          Version D-2010.03                           ***
***                        (1.6, ia32, linux_gnu)                        ***
***                       Copyright (C) 1994-2010                        ***
License checkout failed: Feature start date is in the future.
Feature:       swb_all
License path:  /home/user/synopsys/license/synopsys.dat
FLEXnet Licensing error:-31,34
available at
        * version is "2009.06"
        * server name is "localhost"
        * code is "EDBE970C5C23EFCFB3D9"
        * STROOT is "/home/user/synopsys/D_2010.03/bin/.."
        * user is "root"
发表于 2012-12-3 14:23:20 | 显示全部楼层
同样遇到TCP_NODELAY NOT enabled问题,请教。
发表于 2014-7-29 16:41:36 | 显示全部楼层
回复 1# liuch23
   请问楼主解决了吗 我也遇到了这个问题
发表于 2020-12-14 11:51:24 | 显示全部楼层
请问您当时是怎么解决这个问题的啊?
GMT+8, 2025-12-17 07:13 , Processed in 0.022314 second(s), 7 queries , Gzip On, Redis On.
