查看: 5706|回复: 19
Sentaurus200809安装
发表于 2010-1-6 14:54:38 | 显示全部楼层 |阅读模式
I have tried hard to install it,But there is still some problem with my license feature,I think I can't fix it out.  please help me!!!   ( system:redhat as4)
% lmgrd
% 14:36:03 (lmgrd) -----------------------------------------------
14:36:03 (lmgrd)   Please Note:
14:36:03 (lmgrd)
14:36:03 (lmgrd)   This log is intended for debug purposes only.
14:36:03 (lmgrd)   In order to capture accurate license
14:36:03 (lmgrd)   usage data into an organized repository,
14:36:04 (snpslmd)
14:36:04 (snpslmd) Licenses are case sensitive for TE_CATS
14:36:04 (snpslmd)
14:36:04 (lmgrd) snpslmd using TCP-port 47675
14:36:04 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
14:36:04 (snpslmd) ------------------------------------------------------------------
14:36:04 (snpslmd) Checking the integrity of the license file....
14:36:04 (snpslmd) Valid SSS feature found.
14:36:04 (snpslmd) The feature is needed to enable the other keys in your license file.
14:36:04 (snpslmd)
发表于 2010-1-6 20:13:05 | 显示全部楼层
thanks for sharing
 楼主| 发表于 2010-1-11 08:25:29 | 显示全部楼层
问题已经解决了。换了一个synopsys.src,在论坛里面有一个最全synopsys.src,用他后,虽然仍旧如此,但是GENESISe发现,居然可以了。。。
问题也可能出在:hostname上面,要对系统的hostname修改比如/sysinit/network  , etc/hosts , 终端:
hostname XXX,生效。
发表于 2010-1-15 12:21:38 | 显示全部楼层
2# djx820 xiexie
发表于 2010-1-21 23:47:32 | 显示全部楼层
谢谢分享!
发表于 2010-4-6 13:42:14 | 显示全部楼层
fu*ck you
发表于 2010-4-15 20:19:01 | 显示全部楼层
感激不尽
发表于 2010-4-15 22:30:46 | 显示全部楼层
多谢分享……
发表于 2010-4-15 22:38:04 | 显示全部楼层
多谢分享……
发表于 2010-6-24 16:47:22 | 显示全部楼层
做个记号,以备不时只需!
GMT+8, 2025-12-28 23:20 , Processed in 0.194658 second(s), 6 queries , Gzip On, Redis On.
