楼主: christon
[资料] 【免费】发几篇最近两年(2008年和2009年)RFIC transceiver的Thesis
 楼主| 发表于 2009-12-21 21:55:00 | 显示全部楼层
[Thesis][2008]2GHz transmitter design based on 0.18 muM CMOS process and its linearization and 8 GHz transceiver design based on 0.25 muM silicon germanide bipolar process using GSML method
ABSTRACT
2 GHz CMOS transmitter was designed and implemented. The architecture of the
CMOS transmitter integrated I/Q modulator, a variable-gain pre-amplifier, two LO
buffers and a polyphase filter. The baseband which was generated from a FPGA board
was upconverted by the transmitter. The output power of the upconverted RF signal was
controlled in the transmitter using a gain-controlled stage of the current steering
structure which featured in the preamplifier.
In this work, digital predistortion technique with I/Q signal balancing process was
used to linearize a CMOS transmitter and provide a harmonic free output spectrum.
Correction odd harmonics of the baseband signal were generated and injected at the
baseband input ports along with an original baseband signal. It was verified that well-
controlled odd harmonics of the baseband signal attenuate unwanted harmonics
products located in the RF band and generate a harmonic free output spectrum.
A 8 GHz SiGe bipolar transceiver was designed and implemented. The transceiver
integrated a VCO, a Darlington-amplifier, a VGDA, and up and down conversion
mixers, which were all independently implemented. Both mixers included baluns inside
each chip.  iii
In this work, a practical layout method called Ground-Shield-Microstrip-Lines
(GSML) was proposed to take care of transmission line loss at a fairly high frequency.
Transmission line loss on the Si substrate is much higher than that on III-V substrate
due to low resistivity on the silicon substrate. GSML provide a simplified parasitic
model because the lines are shielded from the low resistivity silicon substrate which
causes complicated parasitic networks. The accurate and reliable GSML layout
methodology was used in the design of a 8 GHz Transceiver. The ground shield layer is
conformed to the circuit such that the interconnection lines are shielded from the low
resistive silicon substrate. This layout methodology has the advangtage of greatly
simplifying the estimation of the parasitic networks for the interconnection lines at the
expense of introducing trivial amount of loss.  This structure also reduces cross-talk and
noise from the low resistive silicon substrate.
In this work, the GSML method replaced the post layout simulation and reduced
iteration times, increasing efficiency in the design and optimization of the circuit.
This work demonstrated that GSML is an effective and useful layout method which
leads to reliable design even for sensitive autonomous circuits such as oscillators.
GSML provides an alternative RFIC layout  methodology which simplifies design
procedures by eliminating the post layout simulation procedure which is believed not to
be reliable at high radio-frequencies.
abbr_e677e93230fca14fc7abcd6c411fa9d1.pdf
3.23 MB, 下载次数: 54 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-12-21 21:56:54 | 显示全部楼层
终于发完了~
发表于 2009-12-22 11:53:13 | 显示全部楼层
thanks
发表于 2009-12-22 22:22:20 | 显示全部楼层
好东西
发表于 2009-12-22 22:50:44 | 显示全部楼层
Low-Voltage and Low-Power Silicon Transceivers and Receivers for W-Band and D-Band Applications,这篇的文件好像少一个,能不能重新传一下,谢谢
发表于 2009-12-23 00:42:40 | 显示全部楼层
这些可以直接到ucb的网站上下载吧,不过还是赞一个楼主吧
 楼主| 发表于 2009-12-23 18:30:27 | 显示全部楼层
15# yankuangtu2010
我查了一下,就是这4个压缩包,但是压缩包的名字被网站自动修改了,自己按顺序换一个名字就可以(顺序就不知道网站会不会自动修改了)
发表于 2009-12-24 09:49:25 | 显示全部楼层
dddddddddddddddddd
发表于 2009-12-24 09:53:44 | 显示全部楼层
dddddddddddddddddddd
发表于 2009-12-24 09:55:19 | 显示全部楼层
ddddddddddddddddd
GMT+8, 2025-12-3 21:47 , Processed in 0.022935 second(s), 5 queries , Gzip On, Redis On.
