查看: 22121|回复: 64
[原创] 2009 12月JSSC
发表于 2009-12-16 14:59:02 | 显示全部楼层 |阅读模式
开始错发在讨论版了,有点乱,现在整理下重发
A
1、A Chopper Current-Feedback Instrumentation Amplifier With a 1 mHz $1/f$ Noise Corner and an AC-Coupled Ripple Reduction Loop
2、A 1 MHz Bandwidth, 6 GHz 0.18 $mu$m CMOS Type-I $Delta Sigma$ Fractional-N Synthesizer for WiMAX Applications
3、A Low Noise Sub-Sampling PLL in Which Divider Noise is Eliminated and PD/CP Noise is Not Multiplied by $N ^{2}$
4、A 20 W/Channel Class-D Amplifier With Near-Zero Common-Mode Radiated Emissions
5、Low-Power High-Efficiency Class D Audio Power Amplifiers
6、A 12 bit 2.9 GS/s DAC With IM3 $ ≪ -$60 dBc Beyond 1 GHz in 65 nm CMOS
7、A 1.8 V 1.0 GS/s 10b Self-Calibrating Unified-Folding-Interpolating ADC With 9.1 ENOB at Nyquist Frequency
8、A 16-bit, 125 MS/s, 385 mW, 78.7 dB SNR CMOS Pipeline ADC
9、A 130 mW 100 MS/s Pipelined ADC With 69 dB SNDR Enabled by Digital Harmonic Distortion Correction
10、A 12b, 50 MS/s, Fully Differential Zero-Crossing Based Pipelined ADC
B
11、A 78 dB SNDR 87 mW 20 MHz Bandwidth Continuous-Time $DeltaSigma$ ADC With VCO-Based Integrator and Quantizer Implemented in 0.13 $mu$m CMOS
12、Digitally Enhanced Software-Defined Radio Receiver Robust to Out-of-Band Interference
13、An Octave-Range, Watt-Level, Fully-Integrated CMOS Switching Power Mixer Array for Linearization and Back-Off-Efficiency Improvement
14、A Fully Integrated Dual-Mode Highly Linear 2.4 GHz CMOS Power Amplifier for 4G WiMax Applications
15、W-Band CMOS Amplifiers Achieving $+$10 dBm Saturated Output Power and 7.5 dB NF
16、A 150 GHz Amplifier With 8 dB Gain and $+$6 dBm $P_{rm sat}$ in Digital 65 nm CMOS Using Dummy-Prefilled Microstrip Lines
17、A 4.75-GHz Fractional Frequency Divider-by-1.25 With TDC-Based All-Digital Spur Calibration in 45-nm CMOS
18、A 90 nm CMOS Low-Power 60 GHz Transceiver With Integrated Baseband Circuitry
19、A Low-Power, Low-EVM, SAW-Less WCDMA Transmitter Using Direct Quadrature Voltage Modulation
20、A 10.8 mW Body Channel Communication/MICS Dual-Band Transceiver for a Unified Body Sensor Network Controller
C
21、A Single-Chip Dual-Band 22–29-GHz/77–81-GHz BiCMOS Transceiver for Automotive Radars
22、A 2-mm$^{2}$ 0.1–5 GHz Software-Defined Radio Receiver in 45-nm Digital CMOS
23、A 65 nm CMOS Inductorless Triple Band Group WiMedia UWB PHY
24、An Embedded 65 nm CMOS Baseband IQ 48 MHz–1 GHz Dual Tuner for DOCSIS 3.0
25、A 10-Gb/s Compact Low-Power Serial I/O With DFE-IIR Equalization in 65-nm CMOS
26、A 10-Gb/s Receiver With Track-and-Hold-Type Linear Phase Detector and Charge-Redistribution First-Order $DeltaSigma$ Modulator in 90-nm CMOS
27、A 4-Channel 1.25–10.3 Gb/s Backplane Transceiver Macro With 35 dB Equalizer and Sign-Based Zero-Forcing Adaptive Control
28、A 2.0 Gb/s Clock-Embedded Interface for Full-HD 10-Bit 120 Hz LCD Drivers With 1/5-Rate Noise-Tolerant Phase and Frequency Recovery
29、A 40 Gb/s Multi-Data-Rate CMOS Transmitter and Receiver Chipset With SFI-5 Interface for Optical Transmission Systems
30、A Single-40 Gb/s Dual-20 Gb/s Serializer IC With SFI-5.2 Interface in 65 nm CMOS
D
31、A 20-Gb/s Full-Rate Linear Clock and Data Recovery Circuit With Automatic Frequency Acquisition
32、A Charge-Multiplication CMOS Image Sensor Suitable for Low-Light-Level Imaging
33、Pseudo-Continuous-Time Readout Circuit for a 300$^circ$/s Capacitive 2-Axis Micro-Gyroscope
34、A 1.05 V 1.6 mW, 0.45 $^{circ}$C 3 $sigma$ Resolution $SigmaDelta$ Based Temperature Sensor With Parasitic Resistance Compensation in 32 nm Digital CMOS Process
35、A Wireless and Batteryless 10-Bit Implantable Blood Pressure Sensing Microsystem With Adaptive RF Powering for Real-Time Laboratory Mice Monitoring
36、A Wireless IC for Time-Share Chemical and Electrical Neural Recording
37、A Piecewise Linear 10 Bit DAC Architecture With Drain Current Modulation for Compact LCD Driver ICs
JSSC 2009.12 A.part1.rar
4.86 MB, 下载次数: 279 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 A.part2.rar
4.86 MB, 下载次数: 250 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 A.part3.rar
4.79 MB, 下载次数: 226 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 B.part1.rar
4.86 MB, 下载次数: 406 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 B.part2.rar
4.86 MB, 下载次数: 191 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 B.part3.rar
4.86 MB, 下载次数: 211 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 B.part4.rar
4.86 MB, 下载次数: 198 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 B.part5.rar
500.91 KB, 下载次数: 170 , 下载积分: 资产 -2 信元, 下载支出 2 信元
JSSC 2009.12 C.part1.rar
4.86 MB, 下载次数: 226 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 C.part2.rar
4.86 MB, 下载次数: 212 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 C.part3.rar
4.86 MB, 下载次数: 218 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 C.part4.rar
4.86 MB, 下载次数: 202 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 C.part5.rar
4.78 MB, 下载次数: 202 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 D.part1.rar
JSSC 2009.12 D.part2.rar
4.86 MB, 下载次数: 170 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC 2009.12 D.part3.rar
2.8 MB, 下载次数: 177 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-16 15:32:07 | 显示全部楼层
好东西,支持啊!
发表于 2009-12-16 22:26:34 | 显示全部楼层
感谢共享!!!
发表于 2009-12-16 23:16:26 | 显示全部楼层
这么快就上新的了
谢谢楼主
发表于 2009-12-17 00:55:53 | 显示全部楼层
非常感谢!
发表于 2009-12-17 01:06:04 | 显示全部楼层
Thanks!
发表于 2009-12-17 18:55:22 | 显示全部楼层
多谢楼主
发表于 2009-12-18 22:11:00 | 显示全部楼层
xiexie ,louzhu
发表于 2009-12-18 23:34:26 | 显示全部楼层
good!
发表于 2009-12-25 23:09:52 | 显示全部楼层
非常感谢,下了看看
GMT+8, 2025-12-19 07:15 , Processed in 0.033993 second(s), 6 queries , Gzip On, Redis On.
