查看: 8760|回复: 30
TFT LCD中的高速接口设计
发表于 2009-12-9 10:12:54 | 显示全部楼层 |阅读模式
A high speed serial interface is proposed for a mobile
VGA-resolution TFT-LCD driver IC. This high speed serial
interface is intended to replace the legacy RGB interface for the
LCD driver IC's. The transmission channel consists of one clock
and two data differential lines, and thereby we can reduce the
number of signal lines going through the hinge of a mobile phone
from 28 down to 6. The simple synchronization encoding scheme
facilitates the pixel synchronization. All channels conform to Sub
Low-Voltage Differential Signaling (SubLVDS) convention. The
total data transfer rate can be up to 800Mbps for two data
channels.
High speed serial interface for mobile LCD driver IC.pdf
217.57 KB, 下载次数: 276 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-9 13:44:47 | 显示全部楼层
感謝分享
发表于 2009-12-9 17:52:29 | 显示全部楼层
thanks
发表于 2009-12-12 08:14:25 | 显示全部楼层
1# equantum
发表于 2009-12-12 18:17:38 | 显示全部楼层
thanks
发表于 2010-1-6 03:11:11 | 显示全部楼层
thank you
发表于 2010-1-22 15:49:14 | 显示全部楼层
很好呀!
发表于 2010-1-22 22:30:03 | 显示全部楼层
thanks
发表于 2010-1-23 23:16:56 | 显示全部楼层
thanks for sharing!
发表于 2010-1-24 08:36:03 | 显示全部楼层
看起来像LVDS接口!
GMT+8, 2025-12-25 19:30 , Processed in 0.023281 second(s), 6 queries , Gzip On, Redis On.
