查看: 13630|回复: 50
A Low-dropout Regulator with Unconditional Stability and Low Quiescent Current
发表于 2009-12-4 10:09:11 | 显示全部楼层 |阅读模式
Abstract An unconditionally stable low-dropout
regulator (LDO) with ultra low quiescent current is presented.
By using frequency compensation of dynamic miller on the
LDO's structure, the proposed LDO's stability is independent
of the load or off-chip capacitor. The LDO works at a low
quiescent current of approximately 4pA. Low quiescent
current is due to a precision CMOS current reference, which
operates in subthreshold region and generates 3OnA bias
current. The current reference has max-to-min fluctuation of
less than 2.5% over a temperature range of -40°C to 150°C.
The proposed LDO has been implemented in a 0.5-jm CMOS
technology. The experimental results revealed that the LDO
provides a full load transient response of less than 50Os setting
time and less than 75mV overshoots and undershoots.
Moreover, the dropout voltage is 170mV at 150mA loading,
and quiescent current is 4.17pA when output current is
150mA.
A Low-dropout Regulator with Unconditional Stability and Low Quiescent Current.pdf
4.08 MB, 下载次数: 366 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2009-12-5 11:35:06 | 显示全部楼层
xiexie, good paper
发表于 2009-12-5 22:34:12 | 显示全部楼层
kankan
发表于 2009-12-6 15:40:45 | 显示全部楼层
ding,,
发表于 2010-1-16 15:55:55 | 显示全部楼层
this is a good article.I will introdue it to someone
发表于 2010-1-17 00:36:34 | 显示全部楼层
it is good paper
thanks
发表于 2010-1-17 01:16:31 | 显示全部楼层
Unconditional Stability .....
wa!! this is good
3q for share
发表于 2010-1-17 10:20:46 | 显示全部楼层
ddddddddddddddddddd
发表于 2010-1-18 13:07:33 | 显示全部楼层
xiexie, good paper!!
发表于 2010-1-18 15:06:55 | 显示全部楼层
thx ,good
GMT+8, 2025-12-24 18:02 , Processed in 0.028259 second(s), 7 queries , Gzip On, Redis On.
