查看: 21882|回复: 42
LicGen0.4b可成功运行lmgrd,但vcs还是起不来
发表于 2009-11-25 13:50:23 | 显示全部楼层 |阅读模式
经过2天的努力,我用LicGen0.4b产生的license.dat好像可以用了。我执行
lmgrd -c license.dat -l syn_lic.log
得到的结果是
9:48:55 (lmgrd) -----------------------------------------------
9:48:55 (lmgrd)   Please Note:
9:48:55 (lmgrd)
9:48:55 (lmgrd)   This log is intended for debug purposes only.
9:48:55 (lmgrd)   In order to capture accurate license
9:48:55 (lmgrd)   usage data into an organized repository,
9:48:55 (lmgrd)   please enable report logging. Use Macrovision's
9:48:55 (lmgrd)   software license administration  solution,
9:48:55 (lmgrd)   FLEXnet Manager, to  readily gain visibility
................................中间省略
9:48:55 (lmgrd)   schedule and can be used to track license
9:48:55 (lmgrd)   servers and usage across a heterogeneous
9:48:55 (lmgrd)   network of servers including Windows NT, Linux
9:48:55 (lmgrd)   and UNIX. Contact Macrovision at
9:48:55 (lmgrd)   www.macrovision.com for more details on how to
9:48:55 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
9:48:55 (lmgrd)   for your enterprise.
9:48:55 (lmgrd)
9:48:55 (lmgrd)
9:48:55 (lmgrd)
9:48:55 (lmgrd) The license server manager (lmgrd) running as root:
9:48:55 (lmgrd)  This is a potential security problem
9:48:55 (lmgrd)  and is not recommended.
9:48:55 (lmgrd) FLEXnet Licensing (v10.8.0.1 build 19446) started on aimic1 (linux) (11/25/2009)
9:48:55 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:48:55 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:48:55 (lmgrd) World Wide Web:  http://www.macrovision.com
9:48:55 (lmgrd) License file(s): /opt/licenses/license.dat
9:48:55 (lmgrd) lmgrd tcp-port 27000
9:48:55 (lmgrd) Starting vendor daemons ...
9:48:55 (lmgrd) Started snpslmd (internet tcp_port 32771 pid 5705)
9:48:55 (snpslmd) FLEXnet Licensing version v10.8.0.1 build 19446
9:48:55 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_10.9.1
9:48:55 (snpslmd) Server started on aimic1 for: SSS
9:48:55 (snpslmd) SSS  railmill railmill/ace
9:48:55 (snpslmd) railmill/av railmill/spnx rslv3d
9:48:55 (snpslmd) rslv3dviewer simwave  simwave_epic
9:48:55 (snpslmd) spice_parser techviewer timemill
9:48:55 (snpslmd) VSS-Verilog-PLI VSS-Wave-Display VSS-XP-Accelerator
9:48:55 (snpslmd) Verification-Token Verilog  Verilog-Netlist-Writer
9:48:55 (snpslmd) Verilog-Parser TestManager TestSim
9:48:55 (snpslmd) Ultra37000 VANTIS  VCSCompiler_Net
9:48:55 (snpslmd) VCSDebugger_Net VCSPostProcDebugger_Net VCSRuntime_Net
9:48:55 (snpslmd) VCSTools_Net VDesktop-Debug VDesktop-GUI
...............后面省略
9:48:55 (snpslmd)
9:48:55 (snpslmd) Licenses are case sensitive for TE_CATS
9:48:55 (snpslmd)
9:48:55 (lmgrd) snpslmd using TCP-port 32771
9:48:55 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  avantd  chrysalisd  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  saber_dmn  slat  ssilmd  synopsysd  tmald  vcsd
1:48:55 (snpslmd) ------------------------------------------------------------------
1:48:55 (snpslmd) Checking the integrity of the license file....
1:48:55 (snpslmd) Valid SSS feature found.
1:48:55 (snpslmd) The feature is needed to enable the other keys in your license file.
先前“(snpslmd) Invalid license key (inconsistent authentication code)"
这个句子不见了。 这样是不是license成功了呀?
但是当我执行vcs rtl.v的时候,又出现了
Invalid license file (3)
Please contact VCS Customer Support at 1-800-VERILOG for more information.
而且在画面上也出现
1:50:42 (snpslmd) OUT: "VCSCompiler_Net" [email=user@user1]user@user1[/email]
1:50:42 (snpslmd) IN: "VCSCompiler_Net" user[email=user@user1]@user1[/email]
请问各位好手要怎么解决这个问题? 我用的是 vcs Y-2006.06-6
万分谢谢!
发表于 2009-11-25 14:50:31 | 显示全部楼层
vcs的确不行,版本和你一样
 楼主| 发表于 2009-11-25 15:33:41 | 显示全部楼层
谁知道LicGen 0.4b支援VCS那一版本? 或者
有谁有可以支援 VCS Y-2006.06-6的LicGen或License File?
感激无限。
发表于 2009-11-25 16:57:47 | 显示全部楼层
下40K那个synopsis.src来生成license就可以了,我已经试过了,而且还是floating license
发表于 2009-11-26 18:42:11 | 显示全部楼层
hao hao
 楼主| 发表于 2009-12-2 18:02:37 | 显示全部楼层
可以了 谢谢上面搂主
发表于 2009-12-17 15:48:45 | 显示全部楼层
哪裡可下40K的
可以給個link麼
发表于 2009-12-17 17:25:33 | 显示全部楼层
这里有,我修改了这个src文件,添加了leda的相关feature。
synopsys40k.rar
8.81 KB, 下载次数: 316 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-17 21:57:38 | 显示全部楼层
这个40k的feature还是不全。
缺乏VCSMXRuntime_Net,VCSMXiRuntime_Net,手动添加。
发表于 2009-12-18 15:11:56 | 显示全部楼层
但是那个20K的里面反而有,我检查后发现!
GMT+8, 2025-12-18 12:13 , Processed in 0.025849 second(s), 6 queries , Gzip On, Redis On.
