查看: 7406|回复: 15
small-signal analysis of the phase-shifted pwm converter
发表于 2006-7-14 15:32:34 | 显示全部楼层 |阅读模式
small-signal analysis of the phase-shifted pwm converter.pdf
652.53 KB, 下载次数: 127 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-8-11 11:09:55 | 显示全部楼层
see see?
发表于 2006-8-11 11:10:13 | 显示全部楼层
why cant see?
发表于 2007-1-18 12:22:03 | 显示全部楼层
我来评!!
发表于 2007-1-18 12:22:56 | 显示全部楼层
Abstract-
Abstract
The snecific circuit effects in the phase-shifted
pulse-width-modulated (PS-PWM) converter and their impact
on the converter dynamics are analyzed. The small-signal model
is derived incorporating the effects of phase-shift control and
the utilization of transformer leakage inductance and power
FET junction capacitances to achieve zero-voltage resonant
switching. The paper explains the differences in the dynamic
characteristics of the PS-PWM converter and its PWM coun-
terpart. Model predictions are confirmed by experimental mea-
surements.
发表于 2007-1-18 12:23:45 | 显示全部楼层
REFERENCES
[I] Z. D. Fang, D. Y. Chen, and F. C. Lee, “Designing a high frequency
snubberless FET power inverter,” in Proc. POWERCON 1 1 , vol.
121 R. A. Fisher, K. D. T. Ngo, and M. H. Kuo, “500 KHz 250 W dc-
dc converter with multiple output controlled by phase-shift PWM and
magnetic amplifiers,” High Frequency Power Conversion Con$ Rec.
[3] L. H. Mweene, C. A. Wright, and M. F. Schlecht, “A 1 kW, 500
kHz front-end converter for a distributed power supply system,” in
IEEE APEC’89 Proc., 1989, pp. 423-432.
[4] R. Redl, N. 0. Sokal, and L. Balogh, “A novel soft-switching full-
bridge dc/dc converter: Analysis, design considerations, and experi-
mental results at 1.5 kW, 100 kHz,” IEEE Power Electronics Spe-
cialists’ Con5 Rec., 1990, pp. 162-172.
[5] J. A. SabatC, V. VlatkoviC, R. B. Ridley, F. C. Lee, and B. H. Cho,
“Design considerations for high-voltage high-power full-bridge zero-
voltage-switched PWM converter,” lEEE APECPO Proc., 1990, pp.
[6] V. VorpCrian, R. Tymerski, and F. C. Y. Lee, “Equivalent circuit for
resonant and PWM switches,” IEEE Trans. Power Electron., vol.
PE-4, no. 2, pp. 205-214, April 1985.
[7] V. VlatkoviC, J. A. SabatC, R. B. Ridley, F. C. Lee, and B. H. Cho,
“Small-signal analysis of zero-voltage switched full-bridge PWM con-
verter,” High Frequency Power Conversion Con$ ’90 Rec., 1990, pp.
DI-4, 1984, pp. 1-10,
’88, pp. 100-1 IO, 1988.
275-284.
262-272.
头像被屏蔽
发表于 2008-3-18 09:05:51 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-3-9 23:28:04 | 显示全部楼层
wwwwwwwwwwwwwwweeeeeeeeee
发表于 2009-4-17 01:23:20 | 显示全部楼层
下来看看,非常感谢~
发表于 2009-9-13 14:31:56 | 显示全部楼层
下来看看,非常感谢~
GMT+8, 2025-12-25 17:16 , Processed in 0.022519 second(s), 5 queries , Gzip On, Redis On.
