查看: 9241|回复: 20
一些电流检测的专利
发表于 2009-10-30 00:04:01 | 显示全部楼层 |阅读模式
之前发过一些电流检测的总结性文档,看了朋友们的回复,觉得有一些人跟我一样在做这块东西。就把之前收集到的一些电流检测的专利也共享出来。有关于器件的,有关于电路的,希望对大家有用。
Patent.rar
1.79 MB, 下载次数: 564 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-11-1 08:48:45 | 显示全部楼层
Thanks for your material . It is just what I need now.
发表于 2009-11-1 10:27:20 | 显示全部楼层
谢谢楼主分享。
发表于 2009-11-9 05:58:46 | 显示全部楼层
发表于 2009-11-9 14:32:05 | 显示全部楼层
谢谢 !
发表于 2009-11-9 18:58:49 | 显示全部楼层
Thanks for your material 2# intoxicate
发表于 2011-4-7 13:25:00 | 显示全部楼层
High-side NMOS怎么sense 阿
发表于 2011-6-28 13:20:34 | 显示全部楼层
power MOSFET having a current sensing element of high accuracy.pdf
over current sensing circuit for power MOS field effect transistor.pdf
integrated structure current sensing resistor for power MOS devices,particularly for overload self-protected power MOS devices.pdf
high-voltage high-power constant current LED driver device.pdf
Current sensing for power MOSFET operable in linear and saturated regions.pdf
发表于 2011-6-28 17:12:57 | 显示全部楼层
发表于 2011-6-29 02:02:53 | 显示全部楼层
thanks.
回复 支持 0 反对 1
GMT+8, 2025-12-26 20:15 , Processed in 0.424195 second(s), 7 queries , Gzip On, Redis On.
