查看: 52061|回复: 131
[IC经典图书系列]《SystemVerilog Assertions Handbook》
发表于 2006-7-10 20:48:04 | 显示全部楼层 |阅读模式
SystemVerilog Assertions Handbook  --for Formal and Dynamic Verification System Verilog
Author: Ben Cohen, Srinivasan Venkataramanan, Ajeetha Kumari
List Price150.00
Published by: VhdlCohen Publishing
ISBN: 0-9705394-7-9
Book Description
The book is co-authored by Ben Cohen, a well-known consultant and author of several technical books addressing the effective use of Verilog and VHDL for logic design and verification; Srinivasan Venkataramanan, Verification Solutions Applications Engineer at Synopsys, Inc.; and Ajeetha Kumari, an independent consultant in the field of design and verification. The book is intended for engineers involved in the increasingly important task of verifying the functionality of complex digital electronic circuits. It presents Assertion-Based Verification methodology concepts using the SystemVerilog language.
"The SystemVerilog Assertions Handbook provides a clear presentation of concepts with practical examples and appropriate usage of the SystemVerilog language features," said Surrendra Dudani, Synopsys Scientist and a member of the Accellera SystemVerilog Technical Committee. "It is a much-needed guide to more fully capitalize on the many benefits offered by SystemVerilog Assertions." The Accellera SystemVerilog Technical Committee is responsible for maintaining and extending the SystemVerilog language for assertion support.
"This book introduces the concepts and importance of assertion-based verification, and then goes into great depth on how to write both simple and complex assertions," said Stuart Sutherland, consultant for Sutherland HDL, Inc. and author of the book SystemVerilog for Design. "Hundreds of examples illustrate the proper usage of SystemVerilog assertions. These examples serve as a cookbook of assertions that can be applied to a variety of designs."
The SystemVerilog Assertions Handbook explains the various syntax and nuances of the language in an easy-to-read manner with many examples. Using a synchronous, first in, first out (FIFO) design example, the authors demonstrate how assertions are used throughout all phases of the design process. Phases covered include system-level definition, architectural and verification plans, RTL and testbench designs, and formal verification concepts.
"The authors have created an excellent source for mastering the art of assertion-based specification," said Harry D. Foster, chief methodologist at Jasper Design Automation and chairman of the Accellera Formal Verification Technical Committee. "They provide clear explanations and relevant examples throughout the book, including actual results using several commercial electronic design automation software tools."
[ 本帖最后由 vertyang 于 2006-7-10 21:16 编辑 ]
cover
cover
sva_part1.pdf
397.89 KB, 下载次数: 478 , 下载积分: 资产 -2 信元, 下载支出 2 信元
part1
发表于 2006-7-11 13:55:50 | 显示全部楼层
where is other parts? Please.
发表于 2006-7-11 18:21:59 | 显示全部楼层
发表于 2006-7-11 19:32:25 | 显示全部楼层
为什么只有目录?????
 楼主| 发表于 2006-7-14 20:06:10 | 显示全部楼层
Nothing else. I download this from its web pages, and only this.
If someone has the whole, pls upload!
发表于 2006-7-24 10:21:18 | 显示全部楼层
这种说明性的,,怎么可以收钱呢??
发表于 2006-11-15 15:47:35 | 显示全部楼层
楼主怎么这样忽悠人啊
发表于 2006-11-27 21:45:16 | 显示全部楼层
太感谢你了.............
发表于 2006-11-28 01:29:37 | 显示全部楼层
thanks for your information................
thanks.......
发表于 2006-12-1 11:11:13 | 显示全部楼层
GMT+8, 2025-12-25 23:25 , Processed in 0.029612 second(s), 8 queries , Gzip On, Redis On.
