查看: 6656|回复: 10
高速DAC SFDR
发表于 2009-10-16 20:22:30 | 显示全部楼层 |阅读模式
在做低位高速的DAC时,输入信号比较高的频段,仿的时域的波形不好,怎么做FFT频谱分析的时候,SFDR和有效位都很好呢?哪里出问题了呢?
 楼主| 发表于 2009-10-16 20:29:17 | 显示全部楼层
补充一句  从频谱上来看 SFDR 并没有那么高的,怎么显示的结果不对呢?
发表于 2009-10-19 00:09:46 | 显示全部楼层
because dac needs a filter to filter out frequency at sample frequency.
发表于 2010-2-3 13:38:40 | 显示全部楼层
your waveform is not so bad --> no glitches, no periodic distortions
so SFDR is good
发表于 2010-5-16 14:50:48 | 显示全部楼层
可能是你DA本身的过,我推荐给你一颗高速DAC,性能如下:
。4:1 Multiplexing for Each Input Bit of DAC
。Double Sampling Rate (DSR) DAC with Analog Output Sampling
。Rate Twice of Clock Rate
。12-bit, > 8-Gsps DAC Output
。12-bit resolution DAC with Double Data Rate (DDR) Latches
• DAC analog output has sampling rate twice of clock input rate
• Complementary analog outputs with 50-Ω back terminations
• Complementary divided-by-2 and divide-by-4 clock LVDS outputs for data
synchronization
• Divide-by-2 and Divide-by-4 clock output drivers with enable/disable control
without interrupting internal operations of the chip
• On-chip 100 ohm termination between each differential LVDS input data and
RESET pair
• 3.5 W power consumption
• TQFP package with Exposed Pad to enhance grounding and heat dissipation
。Full Spectrum SFDR SFDR 60 dBc
发表于 2010-5-17 15:11:12 | 显示全部楼层
恩 高速很难做啊
发表于 2010-5-21 21:17:28 | 显示全部楼层
频谱看上去很漂亮啊
发表于 2010-5-24 23:38:03 | 显示全部楼层
已经很不错了
发表于 2010-6-5 17:06:53 | 显示全部楼层
学习学习,
发表于 2010-7-1 21:25:32 | 显示全部楼层
ddddddddddddddd
GMT+8, 2025-12-20 13:50 , Processed in 0.020779 second(s), 6 queries , Gzip On, Redis On.
