查看: 8309|回复: 7
Astro安装求助
发表于 2009-10-10 13:42:36 | 显示全部楼层 |阅读模式
装了个Astro2006,也能启动起来,但就是提示no license,下面是错误信息及license的启动情况:
[user@localhost ~]$ Failed to get license key 'Milkyway'.  (No such feature exists (-5,357))
Failed to get license key 'MDataPrep'.  (No such feature exists (-5,357))
Failed to get license key 'Astro'.  (No such feature exists (-5,357))
Failed to get license key 'Apollo'.  (No such feature exists (-5,357))
License initialization failed
No PseudoColor Visual avaiable, try TrueColor instead
Starting a non page replacement mode Milkyway db session...
Maximum memory usage for this session:    26.09 MB
CPU usage for this session: 1 seconds
Exit AMonitor!
[1]+  Done                    Astro
[user@localhost ~]$ lmgrd -c /home/synopsys/Astro2006/license.lic
[user@localhost ~]$  0:52:50 (lmgrd) -----------------------------------------------
0:52:50 (lmgrd)   Please Note:
0:52:50 (lmgrd)
0:52:50 (lmgrd)   This log is intended for debug purposes only.
0:52:50 (lmgrd)   There are many details in licensing policies
0:52:50 (lmgrd)   that are not reported in the information logged
0:52:51 (lmgrd)   here, so if you use this log file for any kind
0:52:51 (lmgrd)   of usage reporting you will generally produce
0:52:51 (lmgrd)   incorrect results.
0:52:51 (lmgrd)
0:52:51 (lmgrd) -----------------------------------------------
0:52:51 (lmgrd)
0:52:51 (lmgrd)
0:52:51 (lmgrd) FLEXlm (v9.50) started on localhost (linux) (10/10/2009)
0:52:51 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
0:52:51 (lmgrd) US Patents 5,390,297 and 5,671,412.
0:52:51 (lmgrd) World Wide Web:  http://www.macrovision.com
0:52:51 (lmgrd) License file(s): /home/synopsys/Astro2006/license.lic
0:52:51 (lmgrd) lmgrd tcp-port 7182
0:52:51 (lmgrd) Starting vendor daemons ...
0:52:51 (lmgrd) Started avantd (internet tcp_port 32782 pid 6460)
Incorrectly built binary which accesses errno or h_errno directly. Needs to be fixed.
0:52:51 (avantd) FLEXlm version 7.2g
0:52:51 (avantd) lmgrd version 9.5, avantd version 7.2
0:52:51 (avantd) Server started on localhost for:      Astro
0:52:51 (avantd) Astro-Express Astro-Rail      Astro-Xtalk
0:52:51 (avantd) avanwaveswin  metawaveswin    avanwaves
0:52:51 (avantd) metawaves     hspicewin       hspice
0:52:51 (avantd) vlsi2000      vlsi500         hsptest
0:52:51 (avantd) gemini_hspice APCS            APDP
0:52:51 (avantd) APHPO         Apollo          APPower
0:52:51 (avantd) APSolar               APSolarII       APTime
0:52:51 (avantd) CPI-100               EV-ACCESS       EV-ACCESS_UTIL
0:52:51 (avantd) FPABP         FPDP            FPPRT
0:52:51 (avantd) FPTA          FPTime          HERCULES-CRYPT_XREF_DATA
0:52:51 (avantd) HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_LVS
0:52:51 (avantd) HERCULES-FINDSHORT HERCULES-NETLIST HERCULES-RUN_TRAN
0:52:51 (avantd) HERCULES_HDRC HERCULES_HERC-ADV HERCULES_HERC-BASIC
0:52:51 (avantd) HERCULES_HLPE HERCULES_HLVS   HERCULES_HLVS-DEBUG
0:52:51 (avantd) HERCULES_HLVS-HTML HERCULES_MANAGER HERCULES_MASK
0:52:51 (avantd) HERCULES_RCE  LTL-100_CIF     LTL-100_GDS
0:52:51 (avantd) LTL-100_NDW   MDataPrep       MDynLink
0:52:51 (avantd) Milkyway      MVerilog        NET-TRAN
0:52:51 (avantd) Nova-ExploreRTL-Verilog PlanetPL      polaris-com
0:52:51 (avantd) polaris-signalscan SolarII            STAR-ASCII
0:52:51 (avantd) STAR-CR               STAR-DC         STAR-EX
0:52:51 (avantd) STAR-EX_ERC   STAR-FILTER     STAR-GAZER
0:52:51 (avantd) STAR-LD2LTL   STAR-R          STAR-SYN2STAR
0:52:51 (avantd) STAR-TCAD     STAR-XREF       stars_analog
0:52:52 (avantd) stars_aryred  stars_cmi       stars_csdf
0:52:52 (avantd) stars_hsplnk  stars_ish       stars_linred
0:52:52 (avantd) stars_mr      stars_wsf       starsim
0:52:52 (avantd) tfm           xp              polaris-int
0:52:52 (avantd) polaris-cbs   polaris-mt      APACM
0:52:52 (avantd) APATD         PlanetRTL       Enterprise
0:52:52 (avantd) ENACE         Jupiter         ApolloGA
0:52:52 (avantd) cdsaavmx      cdsaawaves      cdsmetalib
0:52:52 (avantd) cdsnet                SABER_SCOPE     SABER_SKETCH
0:52:52 (avantd) SABER_HARNESS SABER_SCOPE_NETLIST SABER_SKETCH_NETLIST
0:52:52 (avantd) SABER_HARNESS_NETLISTER TESTIFY_NETLISTER SABER_INTERFACE
0:52:52 (avantd) SABER_IF      IQBUS_AUTHOR    AIM_DECRYPT
0:52:52 (avantd) AIM_ENCRYPT   AIM_DEVELOPER   AIM_DEBUG
0:52:52 (avantd) VIEWLOGIC_NET SABER_DEV_MMP   SABER_BUNDLE
0:52:52 (avantd) MODEL_ENCRYPTION GRAPHICS_INTERFACE SABER_SIMULATOR
0:52:52 (avantd) OPT_TEMPLATE_LIB CUSTOM_LIB   HSPICE_MODEL_LIBRARY
0:52:52 (avantd) MODEL_SYNTHESIS ST_LIBRARY    COMPONENT_LIBRARY
0:52:52 (avantd) VEHICLE_ELECTRIC_LIB IQBUS_LIB        aPrv
0:52:52 (avantd) MDataCheck    AstroExp        RailMacro
0:52:52 (avantd) MWAPIaccess   MWAPIdev        MAdv
0:52:52 (avantd) RCXTEO                AstroRail       AstroXtalk
0:52:52 (avantd) APXtalk               JUAPlan         JUAUD
0:52:52 (avantd) JUDP          JUATime         JUAOPAS
0:52:52 (avantd) JUAdvOptB     JUClock
各位好心人给我指点迷津吧!谢谢了!
发表于 2009-10-17 15:11:43 | 显示全部楼层
the same with me
发表于 2010-8-23 10:39:41 | 显示全部楼层
yyyyyyyyyyyy
发表于 2014-4-2 23:05:13 | 显示全部楼层
Good job
发表于 2014-5-4 22:26:48 | 显示全部楼层
同问题,同求
发表于 2016-4-16 17:24:02 | 显示全部楼层
我也是,怎么办
发表于 2016-4-17 18:33:58 | 显示全部楼层
发表于 2018-7-4 20:04:25 | 显示全部楼层
同问题,同求~~~
GMT+8, 2025-12-18 02:35 , Processed in 0.024622 second(s), 7 queries , Gzip On, Redis On.
