查看: 4026|回复: 2
TD-LTE channel spacing Vs TD-SCDMA channel spacing
发表于 2009-10-8 21:02:08 | 显示全部楼层 |阅读模式
Dear all,
I have a question about the channel spacing definition. I hope anyone help me to clarify. For the TD-LTE, the channel spacing could be 1.4, 3, 5, 10, 15 or 20MHz. Let us to take a channel spacing is 5MHz as an example.
In the TD-SCDMA, it also has 1.6MHz channel spacing selection. However, I find it has chip rate = 1.28Mcps. Why TD-LTE does not has chip rate value for each different channel spacing? What is the usage of chip rate?
Another question is about the actual bandwidth calculation. For the TD-SCDMA, the channel bandwidth = 1.6MHz and chip rate = 1.28Mcps. Then, the actual bandwidth for calculation should be 1.6M or 1.28M?
For the TD-LTE, the channel bandwidth = 5MHz. I see the 3GPP document. It said that the useful data must be 90% of energy of bandwidth. Then the actual bandwidth which contains data is 5M x 90% ? Am I correct? If it is incorrect, what is the correct answer?
Thanks
smartchi
发表于 2009-10-19 23:06:24 | 显示全部楼层
看一下通信原理就会懂了。
发表于 2010-6-30 14:17:04 | 显示全部楼层
對啊!!
配合standard
GMT+8, 2025-11-7 05:33 , Processed in 0.021962 second(s), 6 queries , Gzip On, Redis On.
