查看: 5442|回复: 8
VCO的phase noise中的dB/octave
发表于 2006-6-26 14:11:06 | 显示全部楼层 |阅读模式
某文章中有这么一句话:This phase noise is comparable to previously reported HBT DRO performance [I], [4], [6], [18] when normalizing the phase noise to center frequency using a 6 dB/octave frequency relationship represented by the dashed lines.
是不是说振荡频率升高一个octave时,相位噪声第增加6dB可视为相位噪声性能没有恶化?
我是猜的,高手指点一下。
发表于 2006-11-29 18:42:18 | 显示全部楼层
bu dong bu dong
发表于 2006-12-4 17:07:03 | 显示全部楼层
可以用Hspice Simulation出來嗎?
发表于 2006-12-20 03:21:30 | 显示全部楼层
沒看到paper 大概用猜的...意思是說 這篇paper上的phase noise 比參考文獻上效能還好
它是正規化來作比較效能的好壞
发表于 2007-1-1 14:40:19 | 显示全部楼层
thanks for your information.....
thanks.....
发表于 2007-9-5 02:43:05 | 显示全部楼层
Check Leeson's phase noise model, and you will find out that operating frequency doubles, phase noise increases by 6dB.  that is to say, you will always get benefit of phase noise reduction if the same vco is used at lower frequency.  in one word, your conclusion/guess is right.
发表于 2010-11-28 23:11:01 | 显示全部楼层
oh,学习学习
发表于 2016-3-17 23:31:43 | 显示全部楼层
learningf !!
发表于 2016-3-19 16:37:00 | 显示全部楼层
ADS 及HSPICE都可以找到你要的答案
GMT+8, 2025-12-23 22:54 , Processed in 0.040819 second(s), 6 queries , Gzip On, Redis On.
