楼主: fangming070105
请教cadence spectre中flick noise如何仿真?
发表于 2014-8-21 17:01:08 | 显示全部楼层
I have found something useful in cadence community.
http://www.cadence.com/Community/forums/p/25499/1321091.aspx
Noise Summary Example
For a MOS transistor, the individual noise contributors are fn, id, rs and rd.
-fn is the flicker noise
-id is the drain-source resistance thermal noise
-rs is the source parasitic thermal noise
-rd is the drain parasitic resistance thermal noise
For Bipolar transistor, the noise contributors are in rb, ib, rc, ic, fn, re,
and bn.
-rb is the base resistance thermal noise
-ib is the base current shot noise
-rc is the collector resistor thermal noise
-ic is the collector current shot noise
-re is the emitter resistor thermal noise
-bn is the burst noise
-itfz is forward transport current
-ibe(A) Intrinisic B-E Junction Current
-kfn is B-E flicker noise constant
-afn is the B-E flicker niose exponent
-bfn is the B-E flicker noise dependence
For VBIC,  (please also see Solution 11603018 )
- fn is the flicker noise between the node bi and ei.
- fnp is the flicker noise between the node bx and bp.
- fnx is the flicker noise between the node bx and ei.
回复 支持 5 反对 0
发表于 2014-8-26 00:19:17 | 显示全部楼层
回复 11# 笑脸先生
   好像不能解决问题
发表于 2014-8-26 12:20:38 | 显示全部楼层
顶,不错
发表于 2014-9-12 20:11:59 | 显示全部楼层
谢谢楼主分享资料  收下了
发表于 2014-12-6 09:56:58 | 显示全部楼层
感谢各位的讨论
发表于 2014-12-19 22:32:04 | 显示全部楼层
谢谢 很有用
发表于 2015-12-10 13:35:06 | 显示全部楼层
感谢11楼的分享
发表于 2016-1-13 18:36:19 | 显示全部楼层
那究竟该如何仿真呢?
发表于 2022-6-6 20:52:25 | 显示全部楼层
学习一下~~~
发表于 2022-6-7 17:33:11 | 显示全部楼层
笑脸先生 发表于 2014-8-21 17:01
**** 作者被禁止或删除 内容自动屏蔽 ****
大哥好 有没有关于id rs rd之间的关系的讨论呀 我仿真电路 发现似乎id值是另外两个的和 但不确定。而且。出现rs和rd时不会出现id,出现id时,不会出现另外两个。
GMT+8, 2025-12-21 02:41 , Processed in 0.018832 second(s), 5 queries , Gzip On, Redis On.
