查看: 2577|回复: 1
我现在已经实现了一个计时单元,但是我想把输入信号延时“计时单元所计的时间”
发表于 2004-7-21 09:46:07 | 显示全部楼层 |阅读模式
该怎么办呢??
我的计时单元程序为:
--The IEEE standard 1164 package, declares std_logic, rising_edge(), etc.
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity delay300 is
generic(size : integer := 13);
    port (
        clk: in STD_LOGIC;
        reset : buffer STD_LOGIC;
        set : in STD_LOGIC;
        enable : in STD_LOGIC;
        q: buffer STD_LOGIC_VECTOR((size - 1) DOWNTO 0);
        delay300: out STD_LOGIC
end delay300;
architecture delay300_arch of delay300 is
begin
counter : process(clk,reset)
begin
if (reset = '1') then
q <= (others => '0');
elsif (clk'event and clk = '1') then
if (set = '1') then
q <= "0000000000000";
elsif (enable = '1') then
q <= q +'1';
else
q <= q;
end if;
end if;
end process counter;
delay300 <= '1' when q >= "1011101110000"  else '0';
end architecture delay300_arch;
发表于 2004-7-21 10:34:24 | 显示全部楼层
可以检测上升沿开始计数,计到你的delay值后开始输出,再检测下降沿,测到后把计数值往下减,减为0时停止输出。
GMT+8, 2025-12-28 16:20 , Processed in 0.020041 second(s), 7 queries , Gzip On, Redis On.
