查看: 3220|回复: 2
出售H.264
发表于 2009-9-3 15:17:06 | 显示全部楼层 |阅读模式
支持全DAVINCI平台,如dm6467,DM6437,C642x,DM648,DM647,OMAP35x,DM355,DM6446,C6416,当然,同样支持C64XX,如dm642,针对dm642,由于工程简单(您可以修改ti提供的工程),所以没有提供,针对DAVINCI,您可以采用ti提供的工程代码,简单的加入算法,您还可以修改提供的工程,毕竟此工程精悍。统一支持720P,1080P.有问题及时mail(vimc@163.com)-DAVINCI-wideplatform support, such as the dm6467,DM6437, C642x, DM648, DM647,OMAP35x, DM355, DM6446, C6416, of course,the same support C64XX, suchas the dm642, for dm642, simply as aresult of the project (you canmodify ti works), so did not provide forDAVINCI, you can use ti workscode, the addition of a simple algorithm,you can also modify theprovision of engineering, lean, after all, thisworks. Unified supportfor 720P, 1080P. There is the issue of timelymail (vimc@163.com)http://www.pudn.com/downloads182 ... g/detail853284.html(下载地址)
发表于 2009-9-9 15:50:01 | 显示全部楼层
哦,不知道是什么!
发表于 2010-3-25 13:51:44 | 显示全部楼层
kan bu dong
GMT+8, 2025-12-26 10:58 , Processed in 0.080875 second(s), 8 queries , Gzip On, Redis On.
