查看: 37330|回复: 163
送 台湾牛人丁豪笔记Communication systems: Haykin.笔记
发表于 2009-9-3 09:03:25 | 显示全部楼层 |阅读模式
送 台湾牛人丁豪笔记
Ch01_Signal&System
电路学补充---------------------------------------------------------------------------------------1
1-1讯号模型--------------------------------------------------------------------------------------2
1-2傅利叶分析-----------------------------------------------------------------------------------4
1-3傅利叶转换-----------------------------------------------------------------------------------6
1-4Dirac Delta Function-----------------------------------------------------------------------12
1-5System----------------------------------------------------------------------------------------19
1-6带通讯号及系统---------------------------------------------------------------------------22
Ch03_RandomProcess
3-1随机空间--------------------------------------------------------------------------------------1
3-2随机程序之统计性质-----------------------------------------------------------------------2
3-3Power Spectral Density----------------------------------------------------------------------7
3-4常用之随机程序-----------------------------------------------------------------------------9
Ch04_CWMod_Amplitude
AM-------------------------------------------------------------------------------------------------1
AM噪声功能------------------------------------------------------------------------------------4
DSB-SC-------------------------------------------------------------------------------------------5
DSB的噪声功能--------------------------------------------------------------------------------7
QM-------------------------------------------------------------------------------------------------8
VSB------------------------------------------------------------------------------------------------9
电视讯号,VSB+C------------------------------------------------------------------------------11
SSB-----------------------------------------------------------------------------------------------12
SSB的噪声功能--------------------------------------------------------------------------------14
AM立体声多任务--------------------------------------------------------------------------------15
Ch05_CWMod_Angle
FDM-----------------------------------------------------------------------------------------------1
FM--------------------------------------------------------------------------------------------------3
锁相回路PLL------------------------------------------------------------------------------------7
FM之噪声性能----------------------------------------------------------------------------------9
PM------------------------------------------------------------------------------------------------11
FM立体声多任务---------------------------------------------------------------------------------13
Ch06_PulseModulation
取样------------------------------------------------------------------------------------------------1
量化(Quantization) ------------------------------------------------------------------------------3
PCM(Pulse Code Modulation) ----------------------------------------------------------------5
Line Coding--------------------------------------------------------------------------------------6
TDM(Time Division Multiplexing) -----------------------------------------------------------7
DM(Delta Modulation) -------------------------------------------------------------------------8
ch07_BasebandPulseTrans
7-2匹配滤波器(Matched Filter) --------------------------------------------------------------1
7-3错误率分析-----------------------------------------------------------------------------------2
ISI(Inter Symbol Interference) ----------------------------------------------------------------4
相关性阶层编码(Correlative-Level Coding) -----------------------------------------------5
7-7均衡器与多重路径干扰--------------------------------------------------------------------7
ch08_SignalSpace
8-1数学基础--------------------------------------------------------------------------------------1
8-2讯号空间--------------------------------------------------------------------------------------4
8-3讯号在AWGN中同调检测----------------------------------------------------------------5
8-4错误率分析---------------------------------------------------------------------------------11
ch09_PassbandDigitalTrans
Coherent BPSK-----------------------------------------------------------------------------------1
QPSK----------------------------------------------------------------------------------------------2
Offset QPSK--------------------------------------------------------------------------------------4
M-ary PSK----------------------------------------------------------------------------------------5
M-ary PAM---------------------------------------------------------------------------------------6
QAM(M-ary Quadrature Amplitude Modulation) ------------------------------------------7
Coherent FSK-------------------------------------------------------------------------------------9
M-ary FSK---------------------------------------------------------------------------------------11
CPSK连续相位频率键移---------------------------------------------------------------------12
MSK----------------------------------------------------------------------------------------------16
9-4非同调之讯号侦测------------------------------------------------------------------------17
9-5非同调正交调变---------------------------------------------------------------------------18
Noncoherent BFSK-----------------------------------------------------------------------------19
DPSK(Differential PSK) ----------------------------------------------------------------------20
9-8数位调变之比较---------------------------------------------------------------------------22
ch10_SpreadSpectrum
10-1虚拟噪声(Rseudo -Noise Sequence) ---------------------------------------------------1
10-2展频概念------------------------------------------------------------------------------------2
10-3直序展频(Direct-Sequence Spread Spectrum) ----------------------------------------3
ch11_InformationTheorem
11-1消息及火商---------------------------------------------------------------------------------1
11-2资料紧缩(Data Compaction) ------------------------------------------------------------2
11-3离散无记忆信道(DMC) ------------------------------------------------------------------4
ch12_ErrorControlCoding
12-2线性区段码(Linear Block Code) -------------------------------------------------------1
12-3循环码(Cyclic Code) ---------------------------------------------------------------------4
12-4回旋码(Convolutional Code) ------------------------------------------------------------6
ch13_DigitalSignalProcess
13-3Z转换---------------------------------------------------------------------------------------- 1
[ 本帖最后由 hi_china59 于 2009-9-3 13:03 编辑 ]
送 通讯系统.笔记.part1.rar
4.77 MB, 下载次数: 906 , 下载积分: 资产 -3 信元, 下载支出 3 信元
送 通讯系统.笔记.part2.rar
4.77 MB, 下载次数: 878 , 下载积分: 资产 -3 信元, 下载支出 3 信元
送 通讯系统.笔记.part3.rar
4.77 MB, 下载次数: 801 , 下载积分: 资产 -3 信元, 下载支出 3 信元
送 通讯系统.笔记.part4.rar
送 通讯系统.笔记.part5.rar
1.34 MB, 下载次数: 734 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-9-5 23:02:13 | 显示全部楼层
WELL
发表于 2009-9-6 18:34:46 | 显示全部楼层
不错
发表于 2009-9-6 23:44:23 | 显示全部楼层
总结不错,对系统设计很有用
发表于 2009-9-7 02:28:36 | 显示全部楼层
thanks!!
发表于 2009-9-7 09:25:49 | 显示全部楼层
ddddddddddddddddd
发表于 2009-9-7 09:27:10 | 显示全部楼层
dddddddddddddddddddddddddddddddddddd
发表于 2009-9-7 10:40:20 | 显示全部楼层
thanks!!
发表于 2009-9-7 10:51:03 | 显示全部楼层
thanks!!
发表于 2009-9-7 12:25:38 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-30 16:22 , Processed in 0.651633 second(s), 7 queries , Gzip On, Redis On.
